- 22 Sep 2014
- Leicestershire, England
No thanks.
I think you should use the Force.
I disagree.
What about you using the force?
YOUR BASKET
2 x MSI GeForce GTX 980 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £449.99 (£899.98)
2 x AOC G2460PG 24" Widescreen G-Sync 144Hz 1ms Gaming LED Monitor - Gunmetal £359.99 (£719.98)
1 x Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £259.99
1 x MSI Z97 Gaming 7 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £124.99
1 x Corsair Gaming CGK70 Red LED Backlight Keyboard Cherry MX Red Switches - Black (CH-9000069-UK) £109.99
1 x Corsair Gaming CG-H2100 Dolby 7.1 Wireless Headset (CA-9011127-EU) £99.95
1 x EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply £99.95
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £98.95
2 x Corsair Vengeance Pro Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Memory Kit (CMY8GX3M2A2400C11R) £89.99 (£179.98)
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) £89.99
2 x Crucial M500 240GB SATA 6Gb/s Solid State Hard Drive - (CT240M500SSD1) £81.59 (£163.18)
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £77.99
2 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £62.99 (£125.98)
1 x Corsair M65 RGB Black Gaming Mouse - Limited Edition 'Sails' Logo (CH-9000053-NA) £59.99
2 x Corsair AF120 Quiet Edition Low Noise High Airflow - Dual Pack (CO-9050002-WW) £22.00 (£44.00)
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £22.00
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
2 x BitFenix Alchemy Premium Modding LED Strip - Connect White 30cm £16.79 (£33.58)
1 x BitFenix Alchemy 24Pin ATX Extension 30cm - sleeved black/red/black £7.49
2 x BitFenix Alchemy 6pin PCIe Extension 45cm - sleeved black/red/black £5.99 (£11.98)
2 x BitFenix Alchemy Molex to 3x 3-Pin 7V Adapter 20cm - sleeved red/red £5.98 (£11.96)
2 x BitFenix Alchemy 8pin PCIe Extension 45cm - sleeved black/red/black £5.95 (£11.90)
1 x BitFenix Alchemy 8Pin EPS12V Extension 45cm - sleeved black/red/black £4.99
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Red £4.49
4 x BitFenix Alchemy 2pin I/O extension 30cm - Red £3.95 (£15.80)
Total : £3,334.07 (includes shipping : £27.55).
YOUR BASKET
2 x Acer 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red £499.99 (£999.98)
2 x Gigabyte GeForce GTX 970 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card £299.99 (£599.98)
1 x Intel 5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75820K) £299.99
1 x Gigabyte X99 SOC Force Intel X99 (Socket 2011) DDR4 EATX Motherboard £299.99
1 x Kingston Predator 16GB (4x4GB) DDR4 PC4-19200C12 2400MHz Quad Channel Kit - Black (HX424C12PB2K4/16) £239.99
1 x SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black £149.99
1 x NZXT H440 Midi-Tower - Black / Orange £89.99
1 x Raijintek Triton AIO Water Cooling Solution £69.95
2 x Kingston HyperX 3K SSD 120GB 2.5" SATA 6Gb/s Solid State Drive (SH103S3/120G) £64.99 (£129.98)
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £62.99
1 x BitFenix Alchemy Premium Modding LED Strip - Connect White 30cm £16.79
1 x BitFenix Alchemy 24pin ATX extension 30cm - Orange £8.99
6 x Alpenföhn 120mm Wing Boost 2 Plus PWM fan - Orange £8.45 (£50.70)
2 x BitFenix Alchemy 8pin PCI-E extension 45cm - Orange £6.98 (£13.96)
2 x BitFenix Alchemy 6pin PCI-E extension 45cm - Orange £6.49 (£12.98)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Orange £5.99
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Orange £4.99 (£9.98)
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Orange £4.49
4 x BitFenix Alchemy 2pin I/O extension 30cm - Orange £3.95 (£15.80)
Total : £3,215.52 (includes shipping : £27.55).
You are correct. That case hides the PSU anyway so your only see the extensions...
You know me to well Doomedspeed !! I just don't think the op knew what he was getting himself into with Ethermaster about and a £3k budget ... your asking for trouble
Oh I forgot something.....
YOUR BASKET
1 x Mayhems Pastel - Orange Coolant 1L £14.99
Total : £24.59 (includes shipping : £8.00).
