T-REX
Man of Honour
21 May 2012
Dalek flagship
Project T-REX (Paint It Black II).
Tomorrow I will start building a new PC that will get a lot of use next year.
I am not 100% sure what parts I will use as I have a lot of spares and will use what works best. I will list them in the post below as I build the machine.
Eventually the PC will be equipped with some next gen cards when they are available, there is a clue in the title.
The plan is to have two separate waterloops, one for the CPU and one for the GPUs. This will give me the chance to use my chiller on the CPU when needed. To start with there will only be one loop as the GPUs I want are not available yet.
I will be going more for function so please feel free to call my new build ugly, more so because it will be about 95% black in colour so no bright colours.:D
Parts List.
LD V8 case.
Asus RVE X99 Motherboard.
5960X CPU.
Samsung 850 Pro 1TB SSD.
Corsair AX1200i x2 PSUs
Corsiar Black PSU Cable kits x2
Corsair Dominator Platinum DDR4 (4 x 4gb) 3200mhz
XSPC Twin D5 Dual Bay Reservoir/Pump Combo
2 x AX360mm Rads
1 x AX480mm Rad
XSPC Raystorm waterblock
EK Water Blocks EK-FC980 GTX - Acetal+Nickel x4
EK Water Blocks EK-FC980 GTX Backplate - Black x4
Monsoon Chrome fittings
Various Koolance quick disconnects
Primochill Primoflex Advanced Tubing 16/10 - Black x4
More to follow as I add parts.
Thread Navigation Links.
Man of Honour
OP
21 May 2012
Dalek flagship
Build Pictures.
OMG it's green Jim
But at least it is all Aluminium
Some parts (you don't get much with these cases)
Some Rads
Fitting two PSUs
In with the PSUs
Mobo in, it is a good job I won't see most of that red when I am done.
And in with the CPU
One block ready to rock
Add some RAM
Some pumps ready for action
How to get two PSUs running together, with a lead like this.
Tubing
The coolant even though no one will see it.
Only one SSD but 1TB is plenty
And some cards
Just add water.
All wired up, the NV Death Star is operational.:D:)
Man of Honour
OP
21 May 2012
Dalek flagship
Early Bench Scores.
Heaven 4 @1080p
3dmark11 P preset
3dmark11 X preset
Firestrike
Firestrike Extreme
Firestrike Ultra 4K
Skydiver
3dmark Vantage X preset
Some benches like Unigine Valley and 3dmark Vantage on the normal preset are not worth running due to the huge CPU bottleneck.:)
Man of Honour
OP
21 May 2012
Dalek flagship
Bad news, my project has come to a halt as soon as I opened the box the 900D was in.
The side panel was not attached to the case and the top rail that holds it on was completely detached. Short of breaking something I have no way of refitting it.
Other problems,
One of the caddies fell to bits but I managed to reassemble that.
The top fan cover was not properly attached.
Some of the plastic strips that the side panel sits on are missing.
Fortunately this is one of the few things I did not buy from OCUK.
Corsair really need to work on the quality of their cases as this is garbage.
RMA time.
8 Jan 2012
Kaapstad can't believe you have bought another one of these crappy made cases. this is the main reason my PC is still living in boxes. Really think corsair cases leave little to be desired. Hope it get sorted quickly.
Man of Honour
OP
21 May 2012
Dalek flagship
Slight change of plan
I have just ordered a Little Devil V8 with green interior which should work well with NVidia cards.:)
Does anyone know what I can do with the 900D I am RMAing tomorrow, am I within my rights to cancel it all together?
Permabanned
6 Feb 2010
Barnsley
yep i have also had a few and i started loving them but after a weeks or 2 of buzzing and ratting they get old fast.
corsair have a good looks but there need to build a little better.
19 Feb 2007
ArcCorp
If it's within 2 weeks of purchase you can just get a full refund on it, If I understood your question properly.
