- 19 Feb 2007
- Area 18, ArcCorp
I did a run with 4 980 cards and the graphics scores have gone up in 4k Firestrike by around 200 points.
4 ? Can I call you a GPU whore ?
So, does anyone know how DSR works exactly i saw a drop down box in the nvidia panel i ticked ones from 1.20 to 2.0. Didnt really work out what them resolutions were tbh which tbh nvidia should have that info alongside the 1.2x info in the panel.
So does one just tick em, apply then go in game and select a higher res. Which one would be 1440 exactly to tick in the panel?
Where is this DSR option as I can't see it?
You wont see it in SLI. disable SLI and you'll see it in global settings
Urgh, so its useless to me then if it doesnt work with SLI![]()
I have DSR in SLI and have always had it, so yes it should be there.
Seems a lot of people don't have it. Your the lucky one.
https://forums.geforce.com/default/...k-dsr-is-working-in-a-lot-of-games-/?offset=8
The amount of people that have working DSR in SLI far out weighs the amount of people that don't have it.
What display connection are you guys using?
I'm on DVI.
rog swift 1440p
What connection?
Not yet. Nvidia says it's coming soon
works for me with sli ontried out elite with 5***x3*** lol
That's weird I saw a video with Nvidia saying DRS does not work with SLI , but it's working on it. Can't seem to find the vid to help my case?
