- 9 Apr 2012
Has anybody said that because there's less than 4GB of RAM in the iPhone 6, 64-bit is useless?
If so, you're wrong.
Spec junkies will always crave the more power...even if they don't see the extra performance in real use. For those people, happiness is like the light at the end of a never ending tunnel.
Here and now we have the software and the power. Just enjoy it.
If I always waited for the next big jump in performance that's just around the corner I'd probably end up never buying anything.
What do you guys do that need all this oomph? I'm happy (speed wise) with KitKat on my N5 and just tried Lollipop on my N4 and it is fine too.![]()
No you don't, not really. The difference between the performance on the A8/Tegra K1 and the latest Snapdragon 801/805 devices is pretty big, night and day difference in smoothness., mostly because of the stupid high resolutions.
It's already been said, but it's not every year we move over to a new ARM CPU architecture and 64bit support at the same time, we won't see this kind of improvement again for a while so buying the Nexus 6 over the Note 4 Exynos 7 isn't a smart move if you you have the choice, not an easy device to get hold off in the UK.
epeen status. That is all.
So your definition of smart choice is getting a phone based solely on it SoC? Pffft. Please.
Spec is not all that important.
I believe it has Moto X style active display.
So no light?
Noooooooooooooooooooooooooooooooooooooooooooooo![]()
