Sid Meier's Civilization: Beyond Earth Benchmark
Settings.
Simple Rules.
Any normal resolution can be used up to and including 4K.
Please post your GPU and CPU clocks.
Please post your result in the format as shown below in the spoiler.
Please post what drivers you are using.
Please state if you are using DX11 or Mantle.
Converting Results
Thread Navigation Links.
Settings.
DX11
Mantle
To run the benchmark you need to.
Explore to your steam library and right click the Beyond Earth .exe file.
* Click "Properties".
* Click "Set Launch Options".
* Type into the field "-benchmark lategameview" (without the quotations so it reads -benchmark lategameview).
* Click OK and launch the game.
Next time you run the game it will go straight into the benchmark.
Don't forget to apply the correct game settings before starting the benchmark.
Mantle
Simple Rules.
290X @1000/1250
1080p
DX11
290X @1000/1250
4930k @4.0
14.9.2 Driver
1080p
DX11
290X @1000/1250
4930k @4.0
14.9.2 Driver
Converting Results
Please use the utility below.
Credit due to:
Havana_UK for working out how to convert the data.
GoogalyMoogaly for creating the utility.
Gregster for hosting the utility.
Many thanks.
Convert Results Here.
To use
Find your result file "lategameview".
This will be in the "\ProgramFiles(x86)\Steam\SteamApps\common\Sid Meier's Civilization BeyondEarth\" folder.
Use WordPad to open the file.
Copy and paste the contents into the utility above.
Press Calculate FPS.
Credit due to:
Many thanks.
To use
