Think i have seen that option, will give it a try tomorrow as i have to update an application for work.Is there an option in your BIOS called "spread spectrum"?
Flip it off or on (the opposite of what its set to currently)
depends what your cooling can handle.Is there an option in your BIOS called "spread spectrum"?
How come your memory is only 2333 for 24/7 use? Mine is set to 3300Mhz all the time lol![]()
3300? Are you sure about that? What version of CPU-Z are you using lol?
Use 1.70 or later or it reads it incorrectly.
You'll struggle to get 3300 fully stable. To test for stability run 16 instances of memtest pro with 75% allocation and aim for 400% pass. If your OC is unstable it will fall over pretty quickly.
Edit: Sorry if you're running anything below 5960 run 8 instances
Just an example, 2750 run
Sorry if this has been mentioned but it is now possible to max out your RAM with one DIMM:
http://www.extremetech.com/computin...m-ddr4-clears-the-way-for-massive-128gb-dimms
I think it has implications for HEDT, we may be about to see a drastic change in the way we use RAM. Also prices should come down hopefully.
Best part about X79/X99 is the bandwidth, you don't want to be running one DIMM. Speed will be limited on DDR4 as well I'm willing to bet
Lovely clock on that 8 core Silent Scone have you tried to tweak the volts down to around the 1.370 area.
Desktop use and full loads temps are excellent.I'll 2nd that Boomstick777, I was hesitant giving up my Xonar prior to upgrading but the on-board sound quality has won me over.
Looking forward to my Samsung xp941 coming in a few days and another 16GB ram.
, I've got a Samsung 850 Pro 1TB coming, gonna throw all my games on that and keep using this lil 840 Pro 128GB SSD for Windows.
