Not power tools, but hopefully someone in here knows.
Looking for a decent wood glue for furniture making any recomendations? Inside and outdoors.
Better just to use an outdoor waterproof one for everything, or better two get indoor and outdoor ones.
Anyone know the best place to get the sanding pad for the Bosh multitool? Mine have melted![]()
It works well - I have cut wood, aluminium and attempted to cut floor tile (even with a tungsten carbide bit it's not a good idea as be blade overheats). The blades are good, easy to change and widely available.
It's pretty crap all told, for light home diy work I don't think you will have any problems with it though.
As long as the wood doesn't split..
How much do you need to spend to get a decent metric tap and die set? It'll only be used very occasionally for the odd project, but i also want it to actually work and not start mangling the threads after a few uses.
I have seen one by Bergen tools on ebay for about £30 odd, would that be ok?
It's almost Christmas! I need a SDS drill, has anyone spotted any good deals about? Looking at sub £200.00 budget. Also after a cordless, budget very similar. Thanks ~
https://flic.kr/p/qkvWeZ
