MSI Gold Edition GTX970 at Beat IT 2014
19 Dec 2003
Grimsby, UK
KitGuru | 2nd Nov 2014 | 5:38 am. said:
Increased clocks have been made possible by pairing a solid backplate with some specially treated copper to make a heatpipe/fan combo that MSI believes is the best around.
We’ll try to eek the details of that clock improvement from a product manager later today.
In the following pics, you will see some slight colour variations – this was due to the enormous amount of stage lights going off when we accessed the sample. The first one is the most colour accurate.
More info / pics here >> http://www.kitguru.net/components/graphic-cards/andrzej/kitguru-picks-up-an-msi-gold-edition-gtx970-at-beat-it-2014/
But dayum, the cooler itself is ugly in that gold/orange colour
should have just released the backplate as a seperate purchase for the Gaming card imo.
Will be interesting to see what these are clocked at considering 1500 MHz on the core is easy enough on the Gaming Edition, also if the power limit has increased etc. Maybe the BIOS will work on the Gaming Edition?
Probally a crafty marketing gimmick, but I still woudn't mind having one or two, I'm easily lead... :o
Are they still using the **** fans?
Hope not.
MSI's previous top line cards used high quality components with very well made heatsink, and yet they skimped on fan bearing quality by using **** sleeve bearing fans.
Very odd choice by MSI, when you consider Galax use EBR fluid bearing, and EVGA use Dual Ball Bearing.
I'm just happy that they are giving a non top of the line card the gold treatment. I don't think I need gibbo to tell you that the 970 is more popular than the 980
Hope not.
Didn't know that!
Cheers for the info Sean
I bet these definitley have Hynix ram.
I've read that some Gaming Editions have a different BIOS for Hynix versions, guess all the first batches came with Samsung.
Fan used on the MSI GTX 970 4GB Gaming Edition, same as used on previous generation of gaming cards lol. :eek:
Xbitlabs | 10th Sept 2014 said:
The two 100mm Torx Fans are manufactured by Power Logic (the PLD10010S12HH model). The actual diameter of the impellers is 94 mm. The fans feature alternating blades which differ in their angle of attack.
Thanks to the peculiarly-shaped blades and the increased number of them, the fans ensure increased air flow at a 5% noise reduction. The fan regulation algorithm has been optimized as well. The Zero Frozr technology means that the fans are halted altogether in 2D mode and at low 3D loads. Judging by monitoring data, they start working as soon as the GPU temperature hits 60°C. And they do so very smoothly, without a sudden acceleration as is often the case with other coolers. The fans run on sleeve bearings with increased service life.
Link >> http://www.xbitlabs.com/articles/graphics/display/msi-geforce-gtx-970-gaming_3.html
