- 22 Jul 2012
- London
No, you can't and I want Arnie back
i7 2600k @4.4
I might after keep this CPU back at 4.4ghz didn't think the gap was this much.
Over to you Greg![]()
Can i play?#Flex
X4![]()
Sorry for the crappy handheld recording.![]()
No, you can't and I want Arnie back![]()
Lol.... ^^^^
I managed to get my CPU stable at 4.8Ghz, but its not ideal, 1.52v, which in its self is not a problem, the problem is my Cooler Master Seidon 120V can't deal with the heat that voltage results in long term.
I need a better cooler...
Can i play?#Flex
X4![]()
https://www.youtube.com/watch?v=dkD68H-Sxgk
Here is mine with my GPUs at 1146Mhz/3758Mhz and stock CPU (3.8Ghz)
Well done Shanks, you have me beat![]()
Can i play?#Flex
X4![]()
Nice
See you now have 80fov also.. I didn't know till today having higher FOV draws extra effects on screen.. I knew it was more demanding but never knew you get more lighting.
Can i play?#Flex
X4![]()
Doesn't increasing FOV change the shape of the picture, IE squeezing more into the same space, so it ends up a bit squashed?
Yeah, if you over do it like some people run 100+ lol 80 or 90fov is the max I would say.. This at 1080p it may change at high res like 100+ at 1440p for example might seem fine.
Thought so, i think i tryed it once at 1080P, ended up with a Fish-Eye effect...
try 80fov its the sweet spot.
