Man of Honour
- 20 Dec 2004
- Tamworth
I was asking about pedals a week or so back.
I'm considering the Fanatecs but was put off the V2's due to stories of the hall sensors needing regular attention. I think maybe the cheaper Elites might be for me.
That said, I'm now biding my time until these get released sometime soon and reviews crop up - http://www.protosimtech.com
would currently need to replace all 3 monitors and that just isn't happening
Too late now anyway. Already bought them.![]()
...I've not been able to play for months as my G25 pedals pot as given up the will to live...
They look awesome, not heard of them before.
Spils, I think some people have had success by swapping the Clutch pot over to the brake, or just using the clutch pedal, not an ideal solution but could get you back up and racing in the short term?
I'm planning an Obutto purchase just as soon as the Rift CV1 is releasedwould currently need to replace all 3 monitors and that just isn't happening
I'm tempted by the GT Omega. It's cheaper to both buy and ship and has the same features. Only question mark in my mind is over build quality.I'm planning an Obutto purchase just as soon as the Rift CV1 is releasedwould currently need to replace all 3 monitors and that just isn't happening
Shaun Cole does have a grating voice, but is a good host and has some good videos on his new SimPit channel. Gangi is just an egotistical moron.Is it just me or are those two incredibly irritating?
Barry Rowlands of the Sim Garage has better reviews than ISR, but he tends to do actual racing hardware such as wheels and pedal sets instead of cockpits.
To give you an idea of how versatile they are, i have mine set up for racing, flight sim & FPS from 1 mounting layout, no tools etc. The only thing i need to do is undo the quick screw and remove the joystick mount which i have in center-stick, because it'd be a PITA getting in/out otherwise. I have a spare mount point which ive put on the side, and so i just twist the screw maybe 2 turns, lift the HOTAS mount out and put it into the side location.Already decided that the Obutto is the one I want, the fact it can be used for normal gaming as well with the keyboard tray.
