- 19 Feb 2007
- Sol
Yes but when your trying to show what dsr at 4k image quality is like to show a mate and then think ill stick it on forums too i decided to use png so less compression otherwise whats the point in showing it if theres compression artifacts, might as well just have shown a 1080p normal screenie. :/
So jpg - normal screenies
png when trying to show the truest image u can as bmp would have been far higher filesize.
Edit but just for you and because i dont think photobucket was showing it properly at the right res.
link to pic
Bitmap has no loss in image quality either but is larger, I always chose BMP over anything else if I want the best quality available in screenies via fraps
