- 3 Nov 2004
- UK
A favour please, could someone with a standard UK Note 4 please give me the part number for the charger, i.e. the 3 pin one with 9v+5v? Many thanks.
SN... R37F8VH3GB1SE3
EP-TA20UWE
Thought I'd try a tempered glass screen protector, so got an Ultimate Shield from Amazon for a tenner...
Is it staying or going in the bin?
I can get tempered glass screen protectors for free to test for a friend. He's given me about 4-5.
The first batch were a reasonably good fit, they cover the entire screen just about. The problem I had though was due to the curved screen, the screen protector does not set around the edges. Not a problem at all when the screen is on because you can't tell, but you can when the screens off. I tried fitting 2 of these and it was the same result each time. I then fitted one on my brothers Note 4 and it was MUCH better than on mine i.e. it was less raised at the edges, in fact it's an almost perfect fit. I then went and tried another on mine but yet again the same result.
I've also tried the second batch which were slightly narrower, but these were also slightly raised at the edges and they didn't cover the entire screen (like in your pics) so I went back to the original ones.
Nothing too bad but it spoils the sexiness a tad.I don't see why you'd buy a tempered glass screen protector to protect your phone from keys - your screen won't be scratched by them anyway.
It will be scratched by sand - but so is a tempered glass one...
