DXOmark have their 7DMK2 sensor analysis up. Slight improvement over the original in terms of high ISO improvement (about 1/3rd of a stop), but no change at all in terms of Dynamic range or colour depth which is disappointing. Still a long way behind Sony, Nikon, Toshiba, Aptina and Samsung sensors in regards DR and colour depth but high ISO is catching up.
To be fair at higher ISO the sensor does quite well, which again points out the biggest issue is Canon's ADC which affects the noise floor. Being a sports camera then high ISO usage is going to be common so the poor overall sensor performance is probably less of an issue than the headlines would indicate.
What is kind of ironic is the Canon G7X which uses a sony 1inch sensor actually get better DR and colour depth at base ISO. The sensor despite being half the size provides twice the DR! Also interesting is the G7X outperforms the latest sony RX100 so either sony has done more tweaks or Canon has tweaked the sensor themselves.
I'm more disappointed in how long it took you to post once the results were up
1/3 to 2/3 improvement, meh. They must have awesome parties in the Canon sensor development team, because they're not doing a lot else!
If I stay with Canon I'll pick up one eventually as the feature set is good. I'm interested to see the results from this chap's review, as well as the D800E. Not that it makes any difference to the sensor performance but it highlights where the wall is for Canon:
http://www.naturescapes.net/forums/viewtopic.php?f=57&t=249565&start=112
