Do I need a new pump?
Permabanned
15 Dec 2008
been working out the flow and pressure drops with my components and what I can work out I will need a new pump.
My components:
EK Supremecy EVO
EK GTX670 full cover block x2
Hardware Labs GTX 240 Extreme
Hardware Labs GTX 360 Extreme
All associated tubing and fittings for the above
I'm only using a simgle 10w Laing DDC with a Bitpower Micro Tank which I feel is not enough?
18w would be better but the 10w will work fine. i run a 10w
1 x 540 rad
1 x EK Supremacy
1 x EK fc770
the flow rate is fine i will be adding a second 770 and i will not be changing the pump.
I'm still running 2 radiators that have above average restriction and an extra GPU block.
Think I might order a new pump to be on the same side.
To be honest, the 10W DDC will be adequate, not brilliant, but replacing it with the 18W version will improve temps only a degree or two I would have thought.
Think you can still modify the 10W DDC into 18W if your handy with a solder iron?
more info plz :D
