- 27 Jan 2009
- Oxfordshire
The 20 key code is working again C55BT-S95HK-HTT3J-B3J3J-5H5CR
5 keys....
5K53J-J9FJ3-BT3JB-3BTT3-9JF5J
Updated first post.
Also added a key for another 5 keys!
Is their level a lot higher than yours? You might need to do some side quests to catch up a bit.
I have a solo Wilhelm on the go and found him to be quite powerful compared to my Coop Nisha. Wolf and saint are great. I upgraded wolf to do corrosive damage and it gets loads of kills.
You could do the quest for Pickle that rewards you with the E-gun, if you haven't already. Its a really good laser weapon and combined with Wilhelms laser boosting skills it should do some real damage.
what is it you'll look at?Completely forgot about the guns
Skeet Firehose is level 16.
Photon Railgun is level 19.
Rhythmic Spitter is level 18.
Double Tap Rifle is level 18.
The gun that seems to be the best is the Rhythmic Spitter, it does explosive damage so I think that helps.
I'm not on it at the moment, will add you tomorrow, thanks for thatwhat is it you'll look at?
Didnt realise your guns were that good lol
Im still trying to use the boganella etc lol all about level 14-16 my guns are
I hate lazer guns, perhaps i just havent got a good one
I just want a top end shotgun with a decent clip size and a decent fire rate assault gun....
Your inventory (can do that in this game now!) and what missions your on/enemies your facing - can perhaps put you on the right track
I won't be on till after 10pm tomorrow night though![]()
