- 11 Apr 2006
- Earth
Wug must have updated overnight because I looked on the list and it didn't have any android 5 lists yesterday afternoon
Cool. Is there an idiots guide?
I just connected the tablet, fired up WUG and accepted all the updates, re-selected the device and software revision (make sure you select Android 5.0), again accept the download (if it wants one).
Make sure (on the tablet) you have Developer Settings turned on, and USB Debugging selected.
Then hit 'Flash Stock + Unroot' (make sure you mark 'Device is On/Normal')... Select 'Download and install' then just let it do it's business...
Mine, on re-boot, was taking ages, so I rebooted it again and it cam up (after 5 minutes) and asked me to set up and log in... Restored the Google Backup from that morning (even Widget positions!!).
Then I Rooted...
It does feel a little faster than on KitKat, but I've now got to set up all my 'other' emails and accounts!!![]()
Yep...
Get a copy of WUG's Nexus Root Toolkit (it does more than just ROOT)
http://forum.xda-developers.com/nexus-4/orig-development/toolkit-wugs-nexus-root-toolkit-v1-8-2-t2015469
Follow that thread... but here's my quick simple way I did it!!...![]()
Yep! I'm on Win8.1 Pro 64bit... have you made sure USB Debugging is switched on??
I did have to download the latest Android SDK manager a few weeks ago and make sure the 'Android Device' in the Device manager was loading the correct driver (from within the SDK package) at one point it said 'ASUS ADB Composite Device' which fudged it! With the correct Driver it should only say 'Android Composite ADB Interface'
Both my Nexus 4 (now replaced with my Lumia 830) and Nexus 7 (2012) connected no problems then!!
Worked like a treat after downloading sdk manager! Many thanks!
Simian said:Quote:
Yeah! for some reason Windows 8.1 loads a different driver, that doesn't quite work!!
Glad it worked!!
Now get some Lollipop goodness on there Pronto!!
Got my ota lollipop and since then the n7 has turned into a lag machine to the point of being practically unusable![]()
