Jack is released, and the only other announced one will be Hammerlock's sister, The Baroness, who apparently will play like a Zero/Siren mix (claims are as yet unproven).
Yeah, i saw Jack, looks "meh". I'll hold out for The Baroness i think.
I should start with a second character anyway. Who's got the most/best elemental effect skills?
Go round the corner from the chest (back up the stairs and left) and you'll find a shift console - you need to pick up the keys from there! Bit odd that one!
As for Elemental Athena's right hand tree is a great shout, constant weapon switching and very active combat - very deadly.
For a defensive style stick with the shield as it can absorb all elements and distribute them accordingly![]()
Go round the corner from the chest (back up the stairs and left) and you'll find a shift console - you need to pick up the keys from there! Bit odd that one!As for Elemental Athena's right hand tree is a great shout, constant weapon switching and very active combat - very deadly.
), plus half a dozen in my build. I seemed to have acquired more Legendaries in BLPS than 1&2 combined and then some.Just finished Nisha(Playthrough 1), just got a few side missions left to do. Tried a little farming on Iwajari, did about 15 runs and got 3 Thingys. Went from level 27 to 31 in that time. So, going by my previous playthroughs, my average for a Thingy, is 1in5, which is not to bad.
Managed to beat the main Boss at level 26, which surprised me.
Also farmed the vendors at (almost) every level and have a bank full of various Legendaries( 3 Gunslinger mods and 3 3DD13s), plus half a dozen in my build. I seemed to have acquired more Legendaries in BLPS than 1&2 combined and then some.
Sounds good, I'm still waiting for my first legendary but I'm only at level 20 on my first playthrough and Blue's are fine so far. How are you getting all the legendaries?
 Once done i'll pick a second character to go through with. Currently Athena, but i keep thinking about it and Jack might not be all that bad after all.Hardly had any legendaries myself other than one I was given. Loads of purples. Used the chest in Concordia a few nights ago and got three lots of pistols in a row.![]()
Level 50 Wilhelm now, just coming up on the end of TVHM then i'm going back to do a load of side quests that had decent rewards at lv50Once done i'll pick a second character to go through with. Currently Athena, but i keep thinking about it and Jack might not be all that bad after all.
Edit, scrap that. Probably wait for The Baroness. Skill tree here: http://thepresequel.com/Aurelia/00000000000000000000000000000000000000
There's a hint of Gaige in there.![]()
I am a fan of Gaige, fave character from BL2.
