No ones interested, back on topic.
Im done.
Hi there
Spoke to LG.
Hoping to get 29" and 34" super-wide flat IPS panels early next year with FreeSync which shall be exclusive to OcUK in UK.
So IPS and Freesync, boooooooooooooooooom!![]()
 Once you go 21.9, there is no going back!Hi there
Spoke to LG.
Please don't Gibbo, I'm desperately trying to save myself for a 4K monitor with FreeSync, please don't start putting temptations in my path!![]()
Hi there
Spoke to LG.
Well i never implied it also just so you know. But AMD normally do inferior versions of products and that is me speaking from experience not brand loyalty because i have none to no one. And what im trying to say is G-Sync is the same you get what you pay for, And im willing to bet on it.
And about the freesync naming, It aint about the cost! It is about all those months AMD spent crying and moaning on forums about the GSync cost as if they had a free versions ready to go. It has been so long people have forgot about how much they dissed it. And in the end only 100 bucks shaved off on thier version?![]()
I can't see any monitor getting an update.
Besides, how does one firmware update a monitor? I'd imagine the only way would be one of those which have a USB Upstream one.
Shanks, your example is also kinda crap because of the FX83/i7 comparison.
I'd never pick an FX83 with any 290X/980, I'd much sooner put them on an i5 4670K.
 and why would you not go FX83?? remember its only for 60fps 1080p it will handle a 290x with easy.
Hi there
Spoke to LG.
If you believe an i5 4670K and FX8350 are equal at gaming, then there's no point going any further.
I'm sure we're always hearing how frame rate isn't the whole story.
And I really don't care what Huddy says (And besides, I've said the same thing anyways, multiple times, but hey ho!)
Shankly,
Don't knock what is known against the unknown-Freesync could be crap, it's not tried and tested.![]()
Will be interesting to find out if it's a one shoe fits all approach with game profiles or whether it's going down the individual driver profile route, Iv'e asked in the ask huddy thread but no reply as yet-if I even get a reply.
Will Cross/Tri/QuadFire work the same as single mode, is there extra driver work required?
Via vga/hdmi/dp cable, using manufacturers stand alone updater within windows.
 I can easy keep doing what I doing right now.Am not saying the FX83 is better than i5 4670k.. Not what I said!
What I said is you will get the same performance from either playing at 1080p 60fps.
Can you actually update a monitors firmware through those cables? Or are you guessing? I literally have no memory of firmware updates on a monitor.
