Beating the PS4 PC build
30 Dec 2011
Essex
Here's a list of parts I have come up with to beat the performance of the PS4 for the same price. OS does not need to be included.
Anything you think could be changed besides SSD since their performance does not justify their price, at least for this build.
YOUR BASKET
1 x MSI Radeon R9 270 Gaming Edition OC 2048MB GDDR5 PCI-Express Graphics Card £125.99
1 x Asus A88XM-A AMD A88X Chipset (Socket FM2+) DDR3 Micro ATX Motherboard £52.99
1 x Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) HDD £39.95
1 x EVGA 500W 80 Plus Power Supply (100-W1-0500-KR) £39.95
1 x AMD A6-5400K Black Edition 3.60GHz (Socket FM2) APU Trinity Dual Core Processor (AD540KOKHJBOX) £39.95
1 x GeIL Black Dragon 4GB (1x4GB) DDR3 PC3-12800C11 1600MHz Single Module (GD34GB1600C11SC) £32.99
1 x Zalman T2 Plus Mini-Tower USB 3.0 - Black £19.99
Total : £361.40 (includes shipping : £8.00).
YOUR BASKET
1 x Powercolor Radeon R9 270 TurboDUO 2048MB GDDR5 PCI-Express Graphics Card £109.99
1 x TeamGroup Xtreem LV "Frost Edition" 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit £59.99
1 x AMD Athlon X2 370K 3.00GHz (Socket FM2) Dual Core Processor (AD370KOKHLBOX) £41.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £41.99
1 x Gigabyte F2A88XM-DS2 AMD A88X (Socket FM2+) DDR3 Micro ATX Motherboard £39.95
1 x Zalman T1U3 Mini-Tower USB 3.0 - Black £20.99
Total : £368.34 (includes shipping : £11.25).
This Athlon runs at 4GHz (title is wrong), as you are getting an GFX card I moved away from the APU.
Actually...I'm not even sure why I put fast RAM in, its not an APU which would benefit.
A bit over budget but with ps4 games costing so much you will save the money instantly anyway..
Save £10 by adding the evga psu stulid listed instead, missed that.
I reckon the extra cost of the R9 280 could justify the price over the PS4 since it is the best bang for buck card. As for the hard drive I keep to western digital for brands sake.
YOUR BASKET
1 x Sapphire Radeon R9 280 Dual-X 3072MB GDDR5 PCI-Express Graphics Card £161.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £42.95
Total : £406.80 (includes shipping : ).
I did an edit.
Im actually not even sure why I put fast RAM in, it wont need it. An APU does when you use the IGP.
I did an edit.
Would 4GB be enough for gaming, since I have no idea of numbers. I just checked my performance to see I was using 3GB on the desktop so I presumed 4GB would not be enough.
For gaming 4gb is ok depending on what your playing, the problem is skype, chrome and tabs + any other programs that are constantly running using the memory, check in your task manager what is actually using the ram.
There is a similar thread with the z97/g3258 vs am3+ fx 6300, the consensus is if you go for the Intel set up with z97, 8gb ram and a 280x. In the future you can drop an i5/i7 in when the prices come down in the mm. Would make for a great gaming rig anyway.
I will probably go with a bit more then since my friend wants to use Skype and listen to music at the same time.
Case is itx+mATX only.
Out of stock to, as Zalamn are in financial trouble it may never get replenished.
