**** The Official Note 4 thread ****
Kainz.... you can also just tick a box under the security tab in xposed to fix the S health thing.
Also you can get OTA updates still by faking the status of the device from custom to official so you can still get proper updates by ticking another boxed called fake device status.
Aye, I noticed that right afterwards and was like fffffuuu :D I did notice the option to fake the device status so that it looks like a unmodified Note4. I've got it enabled so lets see how it pans out when an update rolls in...at some point.
I tried a Custom rom and kernel but ended up with some very weird GPU slowdown problem. Randomly my GPU speed would just tank and the homepages would get really jerky like it was running about 5fps lol. Went back on stock and everything is fine now.
I don't think theres much point doing anything really until 5.0 is out. Im personally going to do a full wipe when that's available to avoid any issues.
Very good quality as usual from spigen.
Think i would have preferred a slightly softer feeling material on the back but i can live with it.
in my opinion is the best looking "slim" case for the note 4.
Oh and if you use the heartbeat sensor thingy on the back, the case makes it pretty much unusable.
I can't find the satin silver in this case?
Hmm....6pm and down to 22% on the battery.
Anything I need to be doing to get better life out of this? Does the battery need a few days to "settle"?
I ordered mine yesterday and was delivered today from mobilefun. My verus thor will be here tomorrow.
Anyone got a decent screen protector? I got a pack of invisible defenders today but haven't had a look yet. I would like a tempered glass one but the reviews are a minefield from what I can see.
Oh and what is "halo" that everyone keeps referring to?
Also had my 64gb card turn up.
Thanks, but that's for the Note 3.
edit: yep - it seems a completely unreal decision to remove the option to turn it on or off - I can't understand the reasoning behind it.
I'm going to keep my eye out for a N910C Note 4 from a Samsung store in Korea. Still researching this but it seems the way forward.
Just a heads up if you didn't already know mate, but you will not have any EU warranty if you buy the Korean model.
