(Probably) a simple Macrium image question?
26 Feb 2004
Hampshire, England.
Hi guys,
I've got a Macrium image that I need to restore which I know has malware on it. I'd like to rid the image of malware remotely from a clean system so I open the image but then I find this window:
a little bit contradictory... I want to be able to write to the drive don't I? But then I don't want the changes I make to be temporary and then discarded :confused:
I'm confuesed, which options should/shouldn't I be checking?
Hmm, I'll be honest, its not my image and I want to spend as little time as possible on it, but you're right, a clean install would probably be quickest...
Before I do though, there's definitely no other way as is? :)
Theory;
Mount the existing image as a drive
Make it Writeable
Clean it with antimalware programs
Use Macrium to create a new image from the mounted drive?
If not
Dump the image onto a spare drive
Clean it
Reimage it
I wouldn't waste time trying, but you could restore this to a virtualbox machine, clean it, make a new image.
Might be a bit funny with the 'changed hardware'
If you know the image has malware, then you could restore the image then load Windows into safe mode and run anti-malware programs, such as Malwarebytes and Adwcleaner.
