- 4 Oct 2005
- Herefordshire
Sorry to ask but you haven't dropped volts since your last reading?
Sorry ?
The pump is running flat out btw at num5. its a d5 vario
Just because some may have found it insulting that I suggested you've been a bit silly and turned the pump down. Had to ask to knock out apossible answer.
Only thing I can think of now is maybe by bleeding the system you've actually moved an airlock into a more restrictive area.
Hello,
I was planning on getting the Aquaero 6 and wanted to check that it'll do what I'd like.
I'll have 8 fans, 1 temp sensor, 1 pwm Pump and maybe a flow meter in the future.
will it be able to handle this 'off the shelf' or will I need some of it's add-ons?
I have the 5 XT, paid £103 for it brand new from a competitor, did look at the 6 XT but didn't think it was worth the extra for my needs.
*snip*
interesting,
Do you have the waterblock or any extra cooling on it?
as this might be a nice money saver
Good place to ask I think,
Has anyone got Aquasuite working with Win 10 preview at all? Didn't manage it so far.
I am assuming it works with Windows 8.1?
While the system is on, squeeze the pipe going into your CPU block, let the pressure build then release.... try it on all the pipe work as that usually removes stubborn bubble.
Hi thanks for the reply.
If you checkout the water cooling case gallery. I have put pics up of my build. it would be impossible to do what you suggested worse luck.
Nope, it comes with a decent sized heat sink and it's not hitting the 95c temp limit on my PC.
You tried compatibility mode?
Technical bit:-
http://en.wikipedia.org/wiki/PID_controller
Basically, what I have is, I measure the air temperature coming into the front of the case, versus the water temperature going to my radiators and I calculate the difference - you can create virtual temperature sensors to do this in Aquasuite. This is now my delta T that you see talked about in watercooling reviews.
I then have my fan controllers set with the fans to maintain this at a fixed temperature (called Setpoint control in the software if I remember right). At idle, my fans are off and only occassionally just give the radiators a slight waft of air for a second to keep delta T at 4degC. If I increase the load on my PC, deltaT will start to increase so the controller turns them on for a bit longer and under heavier loads it will run them continuously to keep the temperature difference the same or thereabout. It's fully dynamic so there's no sudden increases in fan speed giving you that annoying sudden ramp up in speed that some controllers give you, all nice and gentle changes.
