Hi there
Some epic discounts on Kingston Savage DDR3 memory here, check them out:
Kingston HyperX Savage Red 32GB (4x8GB) DDR3 PC3-19200C11 2400MHz Dual/Quad Channel Kit (HX324C11SRK4/32) @ £269.99 inc VAT
Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. HyperX Savage is XMP Ready and comes in a range of speeds from 1600MHz to 2400MHz. Its trend-setting design puts you and your system ahead of the game.
Features:-
- Fast - top-performing modules available with low-profile heat spreader
- Unique - red, asymmetrical heat spreader sets new trends for PC builds
- Quality - aluminium die-cast heat spreader with a diamond cut finish
- Design - low profile to fit under oversized CPU coolers
- Reliable - 100-percent factory tested
- Guaranteed - lifetime warranty, free technical support
Specification:-
- Capacity 4GB-8GB (single), 8GB-32GB (kits)
- Frequency Speed 1600MHz, 1866MHz, 2133MHz and 2400MHz
- CAS Latency CL9-CL11
- Voltage 1.5V, 1.65V
- Operating Temperature 0°C to 85°C
- Storage Temperature -55°C to 100°C
- Dimensions 133.35mm x 32.8mm
- Compatible with H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
- Warranty: Lifetime
Was [£299.99] Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
Kingston HyperX Savage Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/16) @ £123.95 inc VAT
Features:-
Specification:-
Was [£149.99] Inc. VAT
Only £123.95 inc VAT.
ORDER NOW
Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/8) @ £62.99 inc VAT
Features:-
Specification:-
Was [£89.99] Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Pretty epic price for this very high-end super quick memory from Kingston which looks absolutely stunning by the way.
Features:-
Specification:-
ORDER NOW
Features:-
Specification:-
ORDER NOW
Features:-
Specification:-
ORDER NOW
