- 9 Apr 2012
No, it cannot be reset, hence the name e-fuse.
Plenty have had their device repaired under warranty with tripped knox on xda.They build in an e-fuse which when you modify your phone, i.e. by rooting, is blown and so they can see if you've ever modified your phone and thus refuse to service your phone.
oh well, i'm sure a workaround will be found in time.
Mine said up to 7 days, but it arrived two days later. That said, I know someone who works for EE and they reckon the quicker way to get your phone is to order over the telephone.Just ordered a black note4 from ee, up to 10working days delivery, is there a stock shortage?
Got 2gb data, unlimited calls/texts, £35.99/m and £40 for the handset.
I had bought the xperia z3compact but I'm finding it a bit small after coming from the note2, going to keep the xperia for running/cycling and the note4 as my daily.
I'm away at the moment with very limited internet, but I can get a us note 4 quite cheap, will it work OK in the uk? Anything I should be aware of? Thanks
Argh! I phoned and cancelled the Argos order ages ago, and now they are sending me messages that it'll be delivered next week!
Their website is currently too busy for me to get access to and I cba with phoning them up again to be put on hold for an hour, and then get through to someone to be told I'm through to the wrong department even though I called the number it states on the website and selected the correct options when prompted, and then put on hold for another half hour!
Just filled out their form online to cancel and will refuse delivery if it is attempted.
