I've not checked but I imagine so. Hard to tell though as it's frame hitching so you can't read the overlay. GPU usage on both cards frequently spikes down to 0-20%.
Surely one of the things the overlay excels in is showing the cause of hitching?
Unless you are talking about the MSI Afterburner overlay; which won't show much. But setter was refering the the perfoverlay in BF4.
Anyone has issues with the last AMD driver?
No, why whats wrong?
The yellow cpu line spiking was more common for me, very odd time though the green gpu line would shoot up quite high too. But yet on the CTE version of the game i had two virtually flat lines throughout an entire round.
I really don't understand all this, its not really a benchmark is it?
Just shows what your fps is?
I'm not running the CTE. Does it run any better?
I been having issues with BF4 lately and GPU and CPU spiking.. Only seems to happen with Crossfire enabled and on both Mantle and Dx11..
When running LatencyMon the issue point at DirectX kernel driver being the issue.
Have you/Can you try the affinity fix I posted above? Interested to see if it helps out in any other situation rather then recent SLI issues
I've not played BF4 for at least 2-3 weeks now so will see how i get on when i fire it up on the new rig.
