- 25 Nov 2011
- The KOP
More CSGO, ACE on Inferno.. Enemy CT was also on for a 5 man kill.. But I had to step up and show who boss
remember you need to use google chrome to see the 60 fps videos![]()
I'll do a 60 FPS Titan Fall one soon.
Raptr is stunning mate. If you want the quality even better, in settings un-tick a setting something called optimise for upload.
This stops the compression effect and I notice no difference in performance hit.
Ah... thats what that does. why thank you.
whats the best balance for Bitrate? about 30Mb/s or the full 50?
I use full 50mb although my hard drive is only 54000rpm I don't notice that much issue. But if I was recording all the time a 72000rpm would be best.
Nice one.
Word. He couldn't post them here though. I've played Fifa with Kun many times and he is not known for quoting shakespeare after a dodgy pass.![]()
youtube will compress it quite badly . think its 8000 kbps for 1080.
50,000 kbps for High-quality uploads for creators
I'm sick of Youtube, your right.
A lot going on on screen and its compressed the crap out of it, IQ is horrible nor is it smooth.
complete wast of time for sharing Gaming Video's, its actually much better to compress it yourself to a reasonable size and share it through a File host.
I feel my quality isn't, that bad vs the raw quality.
Best bet is to download the K-Lite Mega Code pack and install it. Then download virtualdub, go to video, compression and set it to use x264. Go to config/settings when you've selected x264 and select virtualdub hack. Click ok and then click save as avi. That file that you now upload to youtube will be good quality and it won't get ruined.![]()
It might also be because i have a painfully slow upload speed, i think i'm going to switch to fibre after crimbo.
I'll give that a go thanks![]()
Shout if you get stuck. This is what the quality will be like.
That was from back when i had my 2700K and 2x290P reference cards, recorded Hardline Mantle in Windowed mode.
Are you letting youtube finish processing? For example even if you upload 1080p 60fps it will take a while for it to show up on youtube.
Thats not bad
I quite like that game, looking forward to its release.
Well, it says its finished, i click on publish, yes i think so![]()
