- 19 Nov 2011
That top one looks boss, because its so different!
Actually no, they both look boss!
ThanksI'd totally go for that if I were you! I have to say this just keeps getting better and better!
Actually no, they both look boss!![]()
)That's a hard one, because honey comb would suite the build very much. But as you said the industrial look plays a big part in this case, maybe honey combing some metal across some of the edges, not all of them but like little bits growing from the corner, so it looks like bumbles are been honey combing.
(That probably made no sense)
Do you have a 3D model template for your design? I'm not particularly great at CAD, but could see if I could help out with some designs (Granted they won't be great, but could be groundwork for something bigger and better)
I look forward to it tooWow, this is an impressively solid build. How much does the case weigh at the moment?
Looking forward to the finished item!
Wowee, that gives a new meaning to a solid case!I'm unsure, but at least 15Kg just the metal off the top of my head.
Been there, done that, felt the pain and learned the lesson. I still repeat the mistake at least once a year...I have had to needle file adjust EVERY DAMN HOLE!![]()
Out of interest, how do you find a shared workshop you can use? I've been looking for one for carpentry, but had no luck yet.problems of using a shared workshop, have to bring it all with me and take it away.
haha, It's a bit overkill
I can pick it up from any bit and there's no bend or warp, it moves as a solid unit.
yeah, I added a few new holes...to my handBeen there, done that, felt the pain and learned the lesson. I still repeat the mistake at least once a year...
I was pointed to one by a guy at work when I was looking into getting something milled, I got pointed at a great one in edinburgh that has a CNC mill, laser cutter, 3d printer etc. Where abouts are you based? I'll ask when I'm there, there's a fair few dotted around that they communicate with to bulk buy/share resourcesOut of interest, how do you find a shared workshop you can use? I've been looking for one for carpentry, but had no luck yet.
Sorry if I missed it, but do you have any fancy illumination plans?I like this more and moreSorry if I missed it, but do you have any fancy illumination plans?
As for the yellow tray/floor, I like it, though I'm not sure if it would detract slightly from the contrast that the tubing/coolant would have with an all black backdrop and how it would affect things with lighting reflection if that makes sense?
That is a heavy case indeed.
I'm north of Oxford, so somewhere round there would be great. We're meant to be getting a maker centre in Oxford later next year which I'm very much looking forward to!I was pointed to one by a guy at work when I was looking into getting something milled, I got pointed at a great one in edinburgh that has a CNC mill, laser cutter, 3d printer etc. Where abouts are you based? I'll ask when I'm there, there's a fair few dotted around that they communicate with to bulk buy/share resources
15KG.That is a heavy case indeed.
haha, yeah, It's a bit of a handfulWow that's a border-line hernia maker there
Looking good so far![]()
Improvised cutting at it's best.![]()
Nice one man.
