Socket AM3 Horizontal CPU Cooler
18 May 2010
Hi,
So I've discovered that my be quiet dark rock CPU cooler can only be mounted vertically causing it either to suck hot air from my GPU or expel hot air onto my GPU.
I would much rather have a cooler that draws from the right and expels toward the exhaust, anyone know of a high quality Socket AM3 cooler that does this please?
Thanks
Thanks, I was deciding between that and the be quiet when I was looking, wish I got that now
Can you remember if it comes with back plate and what mobo do you have?
It comes with two bags, one containing the Intel set and the other the AMD set. It uses the original AMD backplate. That's for AM3+ though and a Gigabyte board. The only bits I had to remove from the original assembly were the bits the original cooler would hook onto on the front. And the board is a 990XA-UD3.
Edit; here's what it looks like at the back.
And in place.
You'll probably need low profile ram as it over hangs one of the RAM slots on my board and just about clears the stick.
Great thanks again, not sure I know where my original back plate is though if I cant find it I'm a bit stuck.
Ram clearance shouldn't be a problem as the closest slot is free
How loud is it?
I know for a fact that the config is causing my 8350 to hit 60c during gaming as I tested with prime 95 (no gpu heat) and after an hour it only hit 45c so its definitely worth changing I think
How loud is it?
Not bad at all actually. In the previous post with the link to the overclocking post I was stressing it with IBT, which is pretty brutal and it does get loud then. But when running games and compiling Gnome on FreeBSD (which would be about as brutal a task a processor could be put through outside of stressing / benching), it's nowhere near as aggressive in performance as when IBT stressed.
I've three HDD cages in there with an 80mm fan on the back of each of those which are set to kick in when drive temps go over 45c. There's also a 4 bay 2.5 inch / SSD cage in the top slot with 2x40mm fans (and tiny fans are a bitch for pitch) and then the twin fans on the GPU and the two case fans.
Really, you can barely hear the thing over the racket of everything else :D
Cool, pretty tempted to order one and sell my be quiet but going to look for my OEM back plate first hopefully its with my OEM cooler at my parents house!
I plan on fitting some new case fans anyway to bring the total from 3 to 5 so its only going to get louder, I have a Bitfenix recon fan controller so that should help a fair bit
Thanks for your help with this, appreciate it
How loud is it?
You could replace this with a H80i in push pull .... this will help with air flow within the case as well ...
I have one on my 8350 and it seems to work very well.
Thanks but I'm not a fan of those style coolers too many stories of leaking and air coolers can get similar temps when the config is right I just need a horizontal air cooler so it will also be significantly cheaper
OhEsEcks if you read this again can you remember what guide you followed in regards to overclocking your cpu please as ultimately that's why I'm doing this
Thanks
Thanks
I didn't read one :p Just winged it, googled stuff when I didn't know what it was (load line cali) and that post showing my overclock, there was some good info in the rest of the thread. So in the end;
I left all power saving enabled (because I don't need POOWWWA all the time).
I disabled turbo boost (can cause instability from what I read and no need for it since the chip is clocked and will run at that clock when taxed, then ramp down because power saving is still enabled [pretty much manual turbo boosting]).
I set load line calibration to extreme (prevents vdroop which can cause instability from what I read).
Then I just notched the multiplier up to 4.2GHz to see if I could at least boot into Windows. Which I could. But stressing was unstable. So I dropped back to BIOS and increased the vcore a bit, back into Windows, stressed it, stable, back to BIOS, multiplier increase, back into Windows, stressed it. Just kept at that until I found a sweet spot.
That clocking post from earlier, before that post I'd tried 4.6GHz, with the vcore set at I think it was 0.100. It was stable, but it was pulling 1.404v which caused the IBT software to stop the test itself because it was reaching the thermal limit for the chip. So that's when I dropped it to 4.4GHz (left the vcore at 0.100) and it pulls 1.32v at full tilt under stressing, which you saw the results for.
I could probably get 4.5GHz at 1.32v, but I'm not bothered as I'm replacing the board and chip with an i7 and intel board (Linux problems with AMD stuff) and I could probably get 4.6GHz if I read a bit more into FSB clocking. But it seems like too much effort / hassle for not a lot of gains. 4.4GHz is perfectly OK on that for me considering it was my first attempt clocking an AMD chip.
Brilliant thank you for that I will refer back to it when I have my cooling sorted as you have a similar board and chip plus I'm happy to aim for 4.4/4.5ghz
Thanks again for all your help
