Im running 2560 x 1440 at 100hz on my 120hz monitor
interesting....my benq can do 100hz
My Sammy is doing 100Hz@1440p too.
@AMDMatt
Having issues getting the Contour Removal and Fluid Motion options to appear in my CCC. According to the release notes my cards should support them.
Drop me a trust with your DXDIAG and brief system specs please benny.
Omega drivers installed and running like a dream. Will give BF4 a shot later if I get time! Nice work AMD![]()
AMD has a long-standing and once deserved reputation for really awful quality drivers. Several years ago they went on a bender to change that and it did indeed change. Purchased game developer shenanigans aside, they drivers are solid but for some the stigma remains. As you can see from the slide below, the units are reported driver problems per million units sold, they did do what they promised about the time SemiAccurate started telling you it was happening..
Perceptions do not necessarily reflect reality and the net is a morass of loud idiots without a clue or data on both sides, then again what else is new? AMD still has to combat this and the first step is to get people to try their cards to see for themselves. The quality is there, the cost is there, the performance per dollar is there so getting over that initial hurdle is the key.
For anyone getting black borders (16:9 users), you may have to set your desktop resolution to match the game res you plan to use.
http://forums.amd.com/game/messageview.cfm?catid=440&threadid=181926
I still get the borders on one of my screens. Not sure why it doesn't happen on the other and haven't had a chance to try this fix yet.
Yes, it does work.
Setting the desktop res to match the game means no more black borders
Sorry to quote myself![]()
yes Matt please make sure it supports 21:9 resolutions... I wouldn't imagine its that difficult to add those and more and more people are getting them.
I'm using a DVI connect for my 1080 monitor, what are the pro's & cons of going to hdmi?
I read earlier in the thread that I need to use hdmi to get the RGB selection option - anything else worth changing for?
