OcUK Staff
 - 26 Nov 2014
 - Stoke
That's right, we now have pretty much the full range of Seasonic PSU's back at OCUK. Seasonic produce some of the best and most reliable PSU's in the market, and we are very pleased to be able to offer the range once more, including the brand new Snow Silent 1050W 80+ Platinum PSU, available FIRST at OCUK!: -
Seasonic Snow Silent 1050w '80 Plus Platinum' Power Supply - White @ £209.99 inc VAT
Features
- DC to DC Converter Design, provides superior dynamic response, greater stability and maximize 12VDC rail output.
- Seasonic patent pending modular cable back panel, with integrated VRM, reduces internal wiring and increases efficiency & quality.
- Super high efficiency for energy savings.
- Dual sided PCB layout for quality & performance
- High current gold plated terminals, reduces current transmission resistance for increased efficiency.
- Conductive solid polymer aluminum electrolytic capacitors
- Advanced ultra-low resistance, high temperature (105°C) electrolytic capacitors
- Improved load voltage regulation keeps the voltage fluctuations on the 12 V output within 0 % to 2 % with no negative tolerance.
- Multi-GPU technologies supported with 6P and 8P PCI-E connectors
- Active Power Factor Correction [99% PF] for reduced line noise and power distortion.
- Universal AC Input for plug and run anywhere around the world.
- >100,000 hours MTBF
- Dual Copper Bars conduct current more efficiently to reduce impedance and minimize voltage drop.
- Smart and Silent Fan Control [S3FC], fanless up to 50% load, Seasonic patent pending, with fan control selector switch to S2FC
- Hysteresis Fan Control optimizes how frequently the fan switches on and off during Fanless and Silent modes.
- Honghua 12 cm Fluid Dynamic fan for increased airflow, lifetime and reduced noise levels.
- Ultra ventilation [Honey Comb Structure] for increased airflow and reduced noise levels.
- Full-Modular cable connections
- Easy Swap peripheral connectors for easy plug and unplug connection.
- Scratch resistant powder coat paint (matte white)
- Over Power / Over Voltage / Under Voltage / Over Current / Over Temperature/ Short Circuit Protection.
- Energy Star, RoHS, WEEE, ErP Lot 6 & REACH compliant
- cTUVus, TUV, CB, BSMI
- PFC Harmonics compliant, EN61000-3-2: 2000
- CE, FCC, C-tick
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 1 x 8 Pin ATX12V/EPS12V
- 8 x 6+2-Pin-PCIe
- 14 x SATA
- 5 x 4-Pin-Molex
- 1 x FDD
- Warranty: 5yr
Only £209.99 inc VAT.
ORDER NOW
Seasonic 400w FANLESS '80 Plus Platinum' Modular Power Supply @ £99.95 inc VAT
The Platinum Series, certified in accordance to the 80PLUS highest standards, offers the newest technology and innovation for performance and energy savings with up to 92% efficiency and a true power factor of greater than 0.9PF.
- 80PLUS® Platinum Certified Super High Efficiency
- Full Modular Cabling Design
- Fanless- 0dBA
- Patented DC Connector Module with Integrated VRM [Voltage Regulator Module]
- Conductive Polymer Aluminum Solid Capacitors
- Highly Reliable 105°C Japanese Aluminum Electrolytic Capacitors
- Tight Voltage Regulation [±2%]
- Active Power Factor Correction [99% PF Typical]
- High +12V Output
- Gold Plated High Current Terminals
- Dual Sided PCB Layout
- Ultra Ventilation [Honeycomb Structure]
- Multi-GPU Technology Support
- All-in-One DC Cabling Design
- Easy Swap Connector
- Universal AC Input [Full Range]
- 7 Years Warranty
- 33A (396W on the +12V Rail)
Connectors
- Motherboard 24 Pin x 1
- CPU 8/4 Pin x 1
- PCI-E 8-6 Pin x 1
- Molex 4 Pin x 5
- SATA x 6
- Floppy x 1
Only £99.95 inc VAT.
ORDER NOW
Seasonic X-Series 750w '80 Plus Gold' Modular Power Supply @ £126.95 inc VAT
The very first full modular multi-output ATX, high-wattage power supply that has ever obtained the 80PLUS® Gold certification is introduced by Seasonic, this coveted power supply is named “X”.
Featuring a patent pending design of “DC Connector Module with Integrated VRM”, the X Series is set to achieve both near-perfect DC to DC conversion and fully modularized design without compromising efficiency. After a long wait, finally there is a product that delivers the complete package, ultra-high efficiency, greatly improved dynamic response, and customizable cable arrangement that is tailored to meet any individual’s needs.
The X Series adopts a clever “Hybrid Silent Fan Control” design, which offers three distinct operation modes, fanless mode, silent mode, and cooling mode. The X automatically adjusts fan mode and speed according to the ambient temperature level. This brand new design not only optimizes heat dissipation, but also prolongs lifespan of the system by reducing unnecessary fan rotation. To make the X Series even more robust and exciting, Seasonic offers Sanyo Denki San Ace Silent Fan on X, the best fan there is in the industry.
- 80PLUS® Gold Certified Super High Efficiency
- Seasonic Hybrid Silent Fan Control
- Sanyo Denki San Ace Silent Fan
- Highly Reliable Japanese Brand Capacitors
- Tight Voltage Regulation [±3%]
- High +12V Output
- High Current Gold Plated Terminals
- Multi-GPU Technologies Supported
Connectors
- CPU 8/4 Pin x 1
- CPU 8 Pin x 1
- PCI-E 8-6 Pin x 4
- Molex 4 Pin x 5
- SATA x 10
- Floppy x 1
- 5 Years Warranty
Only £126.95 inc VAT.
ORDER NOW
Seasonic 660w '80 Plus Platinum' Modular Power Supply @ £119.99 inc VAT
The Platinum Series features a high-tech LLC/full-bridge circuit topology with a unique integrated DC Connector Panel with an embedded Voltage Regulator Module. This design contributes to a near-perfect DC-to-DC conversion that optimizes efficiency by reducing current loss and impedance.
An industry first, advanced 3 phased (Fanless, Silent and Cooling Mode)thermal control balances between silence and cooling. In addition, a selector switch is provided to allow you to select between the Seasonic S2FC control, without fanless mode or the S3FC fan control, with fanless mode.
- 7 Years Warranty
- DC Connector Panel with Integrated VRM [Voltage Regulator Module]
- Conductive Polymer Aluminum Solid Electrolytic Capacitors
- High Reliability Japanese Grade A Capacitors
- High +12V Output
- Seasonic Patented Hybrid Silent Fan Control
- 55A (660W) on +12V Rail
Connectors
- Motherboard 24Pin x 1
- CPU 8/4 Pin x 1
- CPU 8 Pin x 1
- PCI-E 8/6 Pin x 4
- Molex 4 Pin x 5
- SATA x 10
- Floppy x 1
Only £119.99 inc VAT.
ORDER NOW
CHECK OUT THE FULL SEASONIC RANGE HERE
	Features
- CE, FCC, C-tick
Connectors
- 8 x 6+2-Pin-PCIe
- 14 x SATA
- 5 x 4-Pin-Molex
- 1 x FDD
- Warranty: 5yr
ORDER NOW
- Fanless- 0dBA
- High +12V Output
- 7 Years Warranty
Connectors
- CPU 8/4 Pin x 1
- PCI-E 8-6 Pin x 1
- Molex 4 Pin x 5
- SATA x 6
- Floppy x 1
ORDER NOW
- High +12V Output
Connectors
- CPU 8/4 Pin x 1
- CPU 8 Pin x 1
- PCI-E 8-6 Pin x 4
- Molex 4 Pin x 5
- SATA x 10
- Floppy x 1
- 5 Years Warranty
ORDER NOW
- 7 Years Warranty
- High +12V Output
Connectors
- CPU 8/4 Pin x 1
- CPU 8 Pin x 1
- PCI-E 8/6 Pin x 4
- Molex 4 Pin x 5
- SATA x 10
- Floppy x 1
ORDER NOW
