Yes you'd be best with a quality 750W unit.
Cheers, so this then? EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply @ £89.99 inc VAT
Cheers, so this then? EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply @ £89.99 inc VAT![]()
Cheers, I am sure that will help a number of people out, building basic units etc. Luckily I have no need for an 'ultra-budget' one right now, but I am sure others will!
It's always interesting to get real feedback based on people who see sheer volume as well as reviews, which lets be fair in some cases are from reviewers who have been sent cherry picked rather than retail units.
I realise that this is obviously a question you may not be able to answer for a number of reasons, but out of the 'branded' units/brands that would usually be considered safe bets by many, are there any you would actually advise to avoid right now?
My recommendations are in the OP, those are what I would personally buy. That is all I am saying on the subject, if it is not in the OP I'd not buy it for me personally.![]()
It is already £89.99, you should check our website.![]()
Seasonic never made an ax760, they made the old ax750 which was good. All ax760 are inferior now.
The way to tell is a corsair psu was the old seasonic made units the part code on the box is cmpsu-ax750uk if it is the new part code format cp-9020000-gb then they are made by their newer oem partner (mostly cwt)
This thread is great, It'd be great to see this stickied in the PSU forum, and in future similar opinion pieces done for other components where the market doesn't change too often.
Been meaning to ask how do you rate the Silverstone strider psu's?
