Run it at 100hzthats what im doing, i cap at 100fps anyway
Yeah that's what I was doing, but the higher res and 60hz just felt too choppy.
Do I still need to use Radeon Pro for keeping the clocks at max or have they fixed it in this update?
They do mate, just jump on the MM and grab one!
Quick question regarding CCC.
I play CS:GO with 200 contrast. I would like to create a profile which changes automatically plays csgo at 200 contrast. I tried it out but couldn't find anything. I can change the graphics settings but I don't want to.
Here's a weird one.
Omega Drivers, 295x2 - Crossfire disabled for games with no profile
Far Cry 4 - I've only just started playing it so I don't know if this affects all the drivers, but I run it at 3840x2160/Ultra/SMAA/V-sync off.
Game runs at between 32-40 fps
However, with MSI Afterburner on, I noticed that the GPU wasn't being 100% maxed out at all times and because of this the card was at around 900-950Mhz not the 1018Mhz max clock speed it would normally be at.
I noticed it during the first 'ingame' cutscene when you are sitting at the table with Pagan Min at the start of the game.
Then when it gave you full control it seemed to go to 100% load again until you go downstairs and see the guy (Tao pan?) being tortured. GPU not at 100% load and clocks going down.
It wasn't throttling as the GPU was only at about 60C
GPU2 wasn't in use at all.
Any ideas? I'll post this in the Far Cry 4 thread as well.
Has anyone managed to install omega? I keep getting windows requires digitally signed driver pop ups for kernel and audio.
Hello everyone,
I've noticed that some users are reporting that the Catalyst Omega drivers are failing to install since the drivers are ‘unsigned’ and the device manager shows a Code 52 error. The Catalyst Omega driver is WHQL certified, so all components are signed.
The root cause is Microsoft update KB3004394 – (Windows Root Certificate Program in Windows) which was released yesterday. Uninstalling the update fixes the driver installation issue.
You can read more about the various issues this update causes at the following link:
https://answers.microsoft.com/en-us...s/ace25277-7f65-4486-bc44-c1b106907a18?page=1
The game is very stuttery for me on 290x its the gameHere's a weird one.
Far Cry 3 was the same. Very frustrating, as it's an otherwise great game (3. Not played 4, but I gather it's more of the same)
Suck it and seeVSR is more efficient/will produce a better quality picture?
Also, as I have two monitors, but only game on one, I can leave the second without VSR enabled?
Did they remove scaling options or something? My hdmi secondary hasn't had any scaling issues when I installed the omega drivers?
