- 16 Apr 2011
- South Wales
I do enjoy buying older games for very little, safe in the knowledge that I can play them at high settings.
Windows Vista x64? How come you use that?
4x980 min fps 63.37
Actual in-game minimum will be low to mid 40's.
Eh......are you sure?
If that is the case it makes the benchmarking tool completely useless if it is not reporting the actual frame rate.![]()
You can force higher resolution with commands Kapp in the box that says 'custom cvars', I get just over 100fps with 2x 970's and I'm still CPU bound with just 2 cards at 1440p.
r_width = *****
r_height = *****
Replace the ** with your resolution of choice.
