worth getting the 64gb?
will be adding music/movies/tv etc
cheers
you could use your nipples or anything else for touchID.
I had the same problem, and a full Backup/Restore sorts it out.In iTunes the bar along the bottom which visually shows your storage use, shows 50gb of 'other'
The phone was bought new from Apple, it's not jail broken.
Its not like its only a few MB of old data, were talking around 50gb here!
How do I find out if it's old phone backups?
Thanks.
Haven't read this thread for a few months so apologies if this has been discussed.
Anyone else's front-facing camera slightly misaligned? I only just noticed it and it's doing my head in, can see a small white crescent on the right hand side. Going to take it in to the Apple store on Tuesday and see if they can fix/replace it.
