Same as adaptive vsync/frame limiter but at ccc level?
Frame limiter but at ccc level yes, but vsync or adaptive vsync very unlikely.
Right enough, forgot they're slightly different things
Adaptive V-Sync = V-sync enabled at refresh peak, any drops under it disables.
Frame limiter = Frames limited to a set target, V-Sync always disabled.
iirc some of the guys using frame limiter recommend setting the limit 1 frame below refresh, so 59 FL for 60hz etc...
A nice feature to see at driver level.
didn't even know it could do that on its own lol.Does xfire actually work or is it just that you can't disable it?
Does not have an option for enable or disable, only driver that does is 13.9. How would i found out if it is enabled without the option?
If i use GPUZ it shows the GPU core at 300Mhz & GPU Mem at 150Mhz with 30% fan speed. But when i was using 13.9 and had drivers disabled it said the same when i believe the second card should have been completely off.
While you can check GPUZ graphs, it is easier to just set up Afterburner OSD and see what's happening in game.
Sapphire trixx doesn't work with win8.1? First I've heard of it. Seems to work just fine here.
