- 12 May 2011
- Southampton
I have an old htpc I'd like to play around with and pout xp onto. I get an irql not less or equal error at the exact same point every try. It isn't an overclock and it isn't temps. I've tried both 2GB sticks of RAM.
Googling suggests that it is a driver loading problem and using nlite to make a custom CD with xp sp2 on it which apparently fixes the issue. However when I try to add the contents of my xp CD yo nlite it says it needs an iso image?
Has anyone used nlite before or know a good guide?
