Grid Autosport Benchmark Thread
Man of Honour
21 May 2012
Dalek flagship
Grid Autosport
Settings.
Simple Rules.
Any normal resolution can be used up to and including 4K.
Please post your GPU and CPU clocks.
Please post the resolution used.
Please post your result in the text format as shown below in the spoiler.
Please post what drivers you are using.
* The results file below can be found in the "This PC\Documents\My Games\GRID Autosport\benchmarks\" folder.
* Please post the entire file.
* The pic below is optional.
4 x GTX980 @1342/1752
5960X @4.0
344.75 drivers
2160p
<?xml version="1.0" encoding="UTF-8"?>
<!-- Benchmark Mode Results -->
-<benchmark machine="HAL" date="10:13:43 on 16/12/2014" author="Keve" instruction_set="AVX" directx11_feature_level="11.0">
<totals race_time="00:02:22" total_race_time="00:02:22" total_time="00:02:29" races="1"/>
<fps_race av_fps_ms="8.910872" max_fps_ms="7.477483" min_fps_ms="11.100273" av_fps="112.222458" max_fps="133.734848" min_fps="90.087875"/>
<fps_total av_fps_ms="8.910872" max_fps_ms="7.477483" min_fps_ms="11.100273" av_fps="112.222458" max_fps="133.734848" min_fps="90.087875"/>
-<track totalProfiled="1" numInRotation="1" index="1">
<results av_fps_ms="8.910872" max_fps_ms="7.477483" min_fps_ms="11.100273" av_fps="112.222458" max_fps="133.734848" min_fps="90.087875" battery_percentage_used="0" samples="15990"/>
-<settings route="route_0" name="san_francisco">
<car name="sls" livery="user"/>
<car name="320" livery="06"/>
<car name="sls" livery="04"/>
<car name="320" livery="user"/>
<car name="sls" livery="08"/>
<car name="g40" livery="user"/>
<car name="sls" livery="03"/>
<car name="320" livery="01"/>
</settings>
</track>
-<hardware_settings_config deviceId="0x13C0" version="21">
-<cpu>
<threadStrategy fileStreamProcessor="5" updateProcessor="2" renderProcessor="0" dataSetMonitorProcessor="4" dvdStorageProcessor="7" forceFeedbackProcessor="6" workerMapFile="system/workerMap8Core.xml"/>
</cpu>
-<audio_card>
<dynamic_range value="high"/>
<eq value="flat"/>
<voice_chat enabled="true"/>
<push_to_talk enabled="false"/>
<ai_count value="high"/>
<voice_count value="high"/>
</audio_card>
-<graphics_card firstBoot="true" rating="3">
<directx forcedx10="false"/>
<eyefinity osd="" force=""/>
<stereo enabled="false" convergence="0.5" separation="0.015"/>
<advanced global_illumination="true" forward="true"/>
<intel particle_avsm="false" tree_aoit="false"/>
-<resolution multisampling="8xmsaa" vsync="0" fullscreen="true" aspect="auto" height="2160" width="3840">
<refreshRate rate="59"/>
</resolution>
<gamma level="0.8"/>
<avsm enabled="true"/>
</graphics_card>
<shadows enabled="true" particles="true" maskQuality="2" size="4096"/>
<advanced_fog enabled="true"/>
<particles enabled="true" nearFadeBias="0" lowResScalar="2" dynamicRes="false" wind="true"/>
<crowd enabled="true" detail="4"/>
<cloth enabled="true"/>
<groundcover clutter="true" mode="ultra"/>
<objects maxlod="0" lod="1.5"/>
<trees maxlod="0" lod="3.0" meshes_in_all_passes="true" meshes="true"/>
<vehicles lodQuality="3" characterQuality="4"/>
<track quality="2"/>
<envmap size="1024" mindistance="200.0" scaleminsize="0.1" drawallobjects="true" faces="6"/>
<water detail="3" drawallobjects="true" tessellation="true" scale="2" update="true"/>
<mirrors enabled="true" height="256" width="1024" car_maxlod="0"/>
<skidmarks enabled="true"/>
<dynamic_ambient_occ enabled="true" quality="3"/>
<dynamic_ambient_occ_soft enabled="true"/>
<night_lighting shadowSize="2048" onlyHeadlights="false" shadows="true" lights="0" volumes="true"/>
<textures resolution="2"/>
<shaders quality="2" low_quality="false"/>
<anisotropic max="16" min="4"/>
<physics vehicleDamage="true" environmentalDamage="true"/>
<input device_type="auto"/>
<motion enabled="true" extradata="0" delay="1" port="20777" ip="dbox"/>
<second_screen quality="2"/>
<oculus enabled="true" convergence="1.0" overdrive="true" vignette="true" timeWarp="true" chromatic="true" headMovement="true"/>
</hardware_settings_config>
</benchmark>
Man of Honour
OP
21 May 2012
Dalek flagship
1 GPU 1080p
  1. Score Ave 165.28, Min 138.22, GPU TitanX @1481/2002, CPU 5960X @4.5, Kaapstad Link 353.06 Drivers
  2. Score Ave 134.59, Min 113.62, GPU 980 @1492/2052, CPU 5960X @4.0, Kaapstad Link 347.09 Drivers
  3. Score Ave 126.87, Min 102.30, GPU 780ti @1342/2000, CPU 4790k @4.6, yoyo59 Link 344.48 Drivers
  4. Score Ave 122.73, Min 106.76, GPU 780ti @1240/1840, CPU 4790k @4.8, JeffyB Link 347.09 Drivers
  5. Score Ave 98.31, Min 82.72, GPU 290P @1240/1700, CPU 3770k @4.6, win8.1 Link 14.12 Drivers
  6. Score Ave 97.03, Min 75.83, GPU 390P @1040/1500, CPU 3570k @4.0, p5ychonaut Link 16.9.1 Drivers
  7. Score Ave 91.57, Min 76.98, GPU 970 @1530/2000, CPU 4770k @4.2, GamingSlug Link 344.75 Drivers
  8. Score Ave 90.40, Min 69.30, GPU 290X @1000/1250, CPU 4930k @4.7, Kaapstad Link 14.11.2 Drivers
  9. Score Ave 46.64, Min 36.06, GPU 265 @1050/1400, CPU Q9300 @3.0, UTmaniac Link 15.200.1023 Drivers
2 GPU 1080p
  1. Score Ave 123.92, Min 98.46, GPU 290X @1000/1250, CPU 4930k @4.7, Kaapstad Link 14.11.2 Drivers
  2. Score Ave 120.64, Min 97.59, GPU 970 @1530/2000, CPU 4770k @4.2, GamingSlug Link 344.75 Drivers
3 GPU 1080p
  1. Score Ave 123.96, Min 98.48, GPU 290X @1000/1250, CPU 4930k @4.7, Kaapstad Link 14.11.2 Drivers
4 GPU 1080p
  1. Score Ave 167.45, Min 137.25, GPU 980 @1342/1752, CPU 5960X @4.5, Kaapstad Link 344.75 Drivers
  2. Score Ave 122.39, Min 100.10, GPU 290X @1000/1250, CPU 4930k @4.7, Kaapstad Link 14.11.2 Drivers
Man of Honour
OP
21 May 2012
Dalek flagship
1 GPU 1440p
  1. Score Ave 120.38, Min 97.96, GPU 980 Ti @1515/2000, CPU 4770k @4.5, Robzere31 Link 372.54 Drivers
  2. Score Ave 101.66, Min 82.05, GPU 780ti @1342/2000, CPU 4790k @4.6, yoyo59 Link 344.48 Drivers
  3. Score Ave 101.26, Min 84.60, GPU 980 @1492/2052, CPU 5960X @4.0, Kaapstad Link 347.09 Drivers
  4. Score Ave 92.00, Min 81.54, GPU 780ti @1240/1840, CPU 4790k @4.8, JeffyB Link 347.09 Drivers
  5. Score Ave 85.31, Min 67.68, GPU 290X @1230/1625, CPU 4930k @4.0, Kaapstad Link 14.12 Drivers
2 GPU 1440p
  1. Score Ave 109.75, Min 93.92, GPU 970 @1400/1850, CPU 4770k @4.5, Robzere31 Link 347.88 Drivers
3 GPU 1440p
4 GPU 1440p
  1. Score Ave 163.53, Min 138.91, GPU 980 @1342/1752, CPU 5960X @4.5, Kaapstad Link 344.75 Drivers
Man of Honour
OP
21 May 2012
Dalek flagship
1 GPU 1600p
  1. Score Ave 96.84, Min 78.82, GPU 980 @1492/2052, CPU 5960X @4.0, Kaapstad Link 347.09 Drivers
2 GPU 1600p
3 GPU 1600p
4 GPU 1600p
  1. Score Ave 167.51, Min 132.39, GPU 980 @1342/1752, CPU 5960X @4.5, Kaapstad Link 344.75 Drivers
Man of Honour
OP
21 May 2012
Dalek flagship
1 GPU 2160p
  1. Score Ave 79.62, Min 65.42, GPU TitanX @1481/2002, CPU 5960X @4.5, Kaapstad Link 353.06 Drivers
  2. Score Ave 59.56, Min 48.74, GPU 980 @1492/2052, CPU 5960X @4.0, Kaapstad Link 347.09 Drivers
  3. Score Ave 42.97, Min 35.92, GPU 290X @1000/1250, CPU 4930k @4.0, Kaapstad Link 14.11.2 Drivers
2 GPU 2160p
  1. Score Ave 77.85, Min 28.36, GPU 290X @1000/1250, CPU 4930k @4.0, Kaapstad Link 14.11.2 Drivers
3 GPU 2160p
  1. Score Ave 102.37, Min 27.50, GPU 290X @1000/1250, CPU 4930k @4.0, Kaapstad Link 14.11.2 Drivers
4 GPU 2160p
  1. Score Ave 158.03, Min 122.50, GPU 295X2 @1175/1625, CPU 5960X @4.9, AMDMatt Link 15.5 Drivers
  2. Score Ave 149.53, Min 119.40, GPU 290X @1010/1375, CPU 5960X @4.9, AMDMatt Link 15.3 Drivers
  3. Score Avg 125.25, Min 100.98, GPU 980 @1472/2052, CPU 5960X @4.0, Kaapstad Link 344.75 Drivers
  4. Score Ave 105.68, Min 24.79, GPU 290X @1000/1250, CPU 4930k @4.0, Kaapstad Link 14.11.2 Drivers
Man of Honour
OP
21 May 2012
Dalek flagship
5960X @4.0
344.75 drivers
2160p
</settings>
</track>
-<cpu>
</cpu>
-<audio_card>
<eq value="flat"/>
</audio_card>
</resolution>
</graphics_card>
</benchmark>
Man of Honour
OP
21 May 2012
Dalek flagship
1 x GTX980 @1342/1752
5960X @4.0
344.75 drivers
2160p
-<benchmark machine="HAL" date="11:26:16 on 16/12/2014" author="Keve" instruction_set="AVX" directx11_feature_level="11.0">
<totals race_time="00:02:25" total_race_time="00:02:25" total_time="00:02:33" races="1"/>
<fps_race av_fps_ms="18.998344" max_fps_ms="15.991622" min_fps_ms="23.677385" av_fps="52.636166" max_fps="62.532745" min_fps="42.234394"/>
<fps_total av_fps_ms="18.998344" max_fps_ms="15.991622" min_fps_ms="23.677385" av_fps="52.636166" max_fps="62.532745" min_fps="42.234394"/>
<results av_fps_ms="18.998344" max_fps_ms="15.991622" min_fps_ms="23.677385" av_fps="52.636166" max_fps="62.532745" min_fps="42.234394" battery_percentage_used="0" samples="7680"/>
</settings>
</track>
-<cpu>
</cpu>
-<audio_card>
<eq value="flat"/>
</audio_card>
</resolution>
</graphics_card>
</benchmark>
