The AMD Driver Thread
3 Jul 2014
If you're not already, I'd recommend using the 14.12 driver as that had some Dragon Age improvements in it.
Have you tried both API's in Dragon Age to see which one works best? I've not had any time to test it out myself yet, so I'd give both DX and Mante a try and see which one works best.
Yeah i'm currently running the 14.12 Driver.
Ive tried Mantle but it just turns into a stuttery mess so ive had to stick with DX.
Caporegime
OP
12 Jul 2007
United Kingdom
I thought so really, I'm grabbing an 8GB 290x just after christmas to run in trifire which will hopefully solve a lot of the problems i'm having.
Adding a 8gb 290X to a 295x2 8GB card will still only give you a total usable memory footprint of 4gb. This is because the 295x2's 8gb of video memory is shared between the two gpus, giving them 4gb each.
3 Jul 2014
Hmm, I thought if I put an 8GB 290x in the top pcie with the 295 running below it, it would give me the whole 8GB from the 290x?
I know that the 295X2 is basically a 4GB card, or am I missing something here.
3 Jul 2014
I'm afraid not, it will use the card with the lower memory at the base.
I see, good job I checked I guess :eek:
Hmm, not sure what to do now then, I don't feel like 4GB is enough to run some new and upcoming games in 4k.
I guess ill look into selling this 295x2 and picking up a couple of 8GB 290x's or the 8GB 980's if they're coming out.
Thanks for the help anyway! :D
Caporegime
OP
12 Jul 2007
United Kingdom
That's what I'd do. I have four of the 290X 8GB Sapphire cards from OcuK because i found 4gb to be limiting in quite a few games at 4K and that will only increase as time goes on. I'd recommend two of the Sapphire 290X 8GB Vapor-X cards.
3 Jul 2014
Only if he has very good airflow, 1 of those cards is virtually silent, with 2 inside a case one gets quite a bit hotter and can kick up quite a racket.
I'm not too worried about the noise really.
As far as heat goes I have one of the Aerocool Strike-X cases, cant check which as i'm at work right now but its massive and I can fit a side fan to pull some heat out from between them which should sort it.
Just need to figure out how to get rid of this 295x2 now.
Caporegime
OP
12 Jul 2007
United Kingdom
You'll be fine then.
27 Oct 2010
Hi Matt
Do you know of any issues with the new drivers causing sound problems when v sync is turned on?
Since installing the Omega drivers I seem to be getting sound popping and crackling if I'm playing music as the same time as running a game. As soon as I turn v sync off in game the sound starts playing fine again.
This happens on my wife's system as well. Wondered if this is a known issue? (Didnt have this problem on previous version of driver)
Mine: Win 8.1, R9 295X2
Hers: Win 7, R9 290X
Caporegime
OP
12 Jul 2007
United Kingdom
Hi Matt
Hi,
Could you send me a trust message please and include both DXDIAG reports for both computers?
Do you have any sound cards by any chance?
Caporegime
OP
12 Jul 2007
United Kingdom
hi matt
I have use a single card(R9 290), if I want the max performance
Should i disable ULPS?
thanks.
Up to you, this is how it works for single card and multi card.
ULPS/ZeroCore
One GPU, monitor in power save (blinking amber), GPU shuts down and fan stops.
Two GPU, user working with PC in non-3D app, GPU 2 shuts down and the fan stops.
Two GPU, monitor in power save, both GPUs shut down and the fans stop.
So in other words if you leave it enabled then the gpu and fan will shut down and consume no power when the monitor enters power saving mode. There is no real performance benefit to disabling it, but it won't hurt either. It may give a tiny performance boost, but i doubt you would notice it.
23 Jul 2009
Bath
Hi Matt
Do me a favour and run latencymon (free to download) and see what your DPC latency is like. You may be suffering from the high DPC lag some of us have been experiencing. For me, disabling my secondary monitor in CCC fixes the problem so I can use vsync, as does disabling xfire, otherwise I have to leave vsync off (although this isn't as good as disabling my 2nd screen I've found). Your missus only has a single card so it may be unrelated, but give it a go and see what you get.
27 Oct 2010
Matt
Sent you an email for dxdiag.
Devrij
I have run it and it confirms that with vsync on I get massive latency and not so with it off.
Without Vsync
With Vsync
The without vsync shows some higher than actual cause of the alt tab to desktop to kick it off.
Another interesting thing I have I noticed is that with vsync off and only in the menu of a game if I alt tab to desktop one of the cpu core's usage goes to near max and then the audio starts popping. Will attempt to show it with the screen below:
25 Nov 2011
The KOP
I never updated my latency issues.. My second GPU was faulty it's now back at overclockers waiting replacement.
What you seeing is the same I was getting, does by any chance this happen without crossfire enabled?
And if you leave the game to stutter does your game either crash by driver stopped responding or bsod?
27 Oct 2010
PC doesn't crash, can leave it stuttering for ages and it carries on fine. Eventually I get too annoyed so will turn off vsync or the music.
