- 18 May 2010
- London
Silly question, but you definitely had it enabled in the Nvidia control panel?
yes deffo, because on max 1080p settings with everything turned right up............EVERYTHING.... the GTX 970 only just handles a modern shooter, it's far better in SLI of course, but 1080p is way short of full fat 4K.
Agreed 970 SLI should manage about 60-70FPS on near max 1440p hopefully they fix Assassin's Creed Unity by time I finish my build so I can play that. Like you in end I decided that a single 980 would just not cut it sadly.
I dont know how to look for that m8, sorry..... but their settings look the same on MSI AB.......................but they're deffo working whilst gaming.
my guess is that SLI was either turned off by all the latest drivers, or by all the FAR CRY 4 crashes i've had
Use a program like gpu id mate that should tell you everything you need.![]()
just got it, both cards are enabled and both are the same values, so that's good, i might back off the CPU overclock now, it's a bit high at 4.8 anyway![]()
Yeah that is probably pushing it a bit to much.
it's now at 4.6......... if this remains stable, then i dont mind a couple of new GTXs next year
.... not sure, it was maybe throttling right back and then crashing, whatever the case the cards were far noisier in Daz 3D than in Heaven Benchmark...Very glad to hear you found the problem and the fix works for you.
