Had mine delivered yesterday, very nice!
Looks like Nova Launcher is causing some battery drain which not everyone is having, anybody here had to avoid Nova? That would be a shame although I'm sure it would be fixed shortly.
If you are feeling creative Autodesk sketchbook, my drawing skills leave much to be desired but even i am impressed with what can be achieved with this powerful little app, for a perfect example check out Plunk13' post further up the page.What's some of the best apps to make full use of the S Pen?
Also, where is the calender full screen widget?
As for a calendar widget, check out the S Planner widget there are 4 options to choose from, one of them is a 4x4 full page month calender, the other is a 4x3 month calender with a transparent background (I use this one).
About the widget, I've looked on the store but haven't found anything. Where is this? Currently the only S Planner widget I'm able to get is 2x2.
On mine it shows the standard S-Planner widget with 4 different styles.
thats with no modifications, just Stock BTU ROM, all updates applied.
I use Nova Prime launcher and Velur icon pack.
example
Probably because your using Nova. Check on the stock launcher.This is all I see for S Planner:
[IMGhttp://img.photobucket.com/albums/v642/spacedeck/Screenshot_2014-12-21-22-17-12_zpsru7q0fmg.png[/IMG]
How does everyone else find the heart rate monitor it takes me around 10 attempts to get a reading .
Works every single time for me. Is it in a case?
It's the official back cover flip case replacement.
