If it can easily do 5Ghz i'd be excited but i'm thinking it will be a bust
I read this so often but I don't understand the obsession with 5GHz...?![]()
Nope, but ive owned several ivybridge and haswells at 4.5 which is the same.You've never had a 5Ghz 2600K have you?
is broadwell on a smaller node? cant remember now
if so might be interesting
I suspect the same with skylake too tbh. Seems to be the way with the mainstream cpu's now. The much touted improved thermals on DC were a laugh at best, DC is far warmer than IB or first gen HW.ooOOoo
intel will still make it run hot as hell tho
Intel themselves claim only 3% IPC. In reality that will equate to... *fart*
Ivybridge didnt have the integrated voltage regulator and they were still pretty toasty. Admittedly not just as bad as haswell though. Soldered IHS is what we really need tbh.Skylake should be a cooler running CPU - intel are removing the integrated voltage regulator from Skylake.
