Hi,
Hope you are all having a great Christmas?
Please can you give me some advice on the following, thank you. Sorry for the long post;
I am a virgin broadband user on ADSL (8mbps, £20.35 / month) as they can't provide fibre where i live. Which is ridiculous as i live on a new large housing development. Recently they sent me a message saying they are bumping all users over to talk talk as they basically dont want to support ADSL anymore. I've been with virgin for about 16 years! My phone line is with BT.
So, i am looking for a new provider of either SKY or BT, who provide fibre where i live. The package i am looking at is fibre unlimited at 39 - 40 mbps, per month SKY is £16.40 and BT is £18. I can get the larger 56 - 70 mbps packages on both, but sky did not think it was worth it for what i used (see end of post).
But i am slightly worried about the routers supplied, both have reports of weak wifi range, particularly the sky version. I live in a fairly large detached house, so this i a concern with wifi.
I have also contacted BT twice and was a little bothered that one person said they drill a hole and route a cable into the house. Whilst the other said they do not. Last thing i want is to come home from work to find cables and holes!
Also it seems that the BT home hub 5 is difficult to access and set up port forwarding for online gaming?
So I was wondering what are your experiences with these providers and routers - particularly for online gaming and wifi range. If it helps my internet usage is as below;
Wifi:
2 android mobiles
2 android tablets
1 apple mobile
2 desktop pcs (upstairs)
2 xbox 360's (upstairs)
Wired:
1 smart tv
1 xbox one
1 xbox 360
We dont download movies, music etc. Mostly used for internet pages. My son can use it quite a bit at times for youtube. But mostly used for console gaming, with the biggest downloads being game updates or PC updates. The mobile devices are almost always on and at worst all 3 xbox' s are on at the same time as well.
Thank you.
Wifi:
2 android mobiles
2 android tablets
1 apple mobile
Wired:
1 smart tv
1 xbox one
1 xbox 360
Thank you.
