I have a really strange fault with my graphics card.
It can play any game fine but when I close that game and go back to the desktop then after 15-45 seconds my monitor will turn off, the fans on the 780 will increase to max and I will have to reboot to get a picture back. The OS is still running at this time (stayed chatting to someone on teamspeak when it happened!) but the monitor loses the signal.
I originally thought this was my motherboard at the time, as I was running the below and it was doing the exact same thing (I had a few other issues with the motherboard thus me blaming it):
3570K
P8Z77-V LX2
8GB 1600mhz Patriot Viper
650W PSU
MSI Gamer OC 780
However I have since upgraded to the spec and have the same issue:
4790K
Asus Z97 Pro Gamer mobo
16GB Corsair Vengence 2400Mhz
650W PSU (same)
MSI Gamer OC 780 (same)
The more graphic intensive the game the more likely it will happen, never during the game, just after I close it.
What I have done to try resolve this:
* Swapped Mobo, RAM, CPU
* Multiple OS reinstalls
* Multiple Nvidia driver versions
* Stock clocks for everything (both on new and old PC)
PC logs don't highlight anything, aside from the loss of power by holding the power button. The driver itself doesn't crash (or doesn't whilst the monitor is still on).
I am baffled and can only believe its the card, especially after it being tested in essentially two different PCs with different/clean OS installs.
Any ideas as I am all out!
3570K
P8Z77-V LX2
650W PSU
MSI Gamer OC 780
4790K
650W PSU (same)
