The spec is much better, but it's also significantly more expensive and, when it comes down to it, still only plays the same videos.
~£60
Once you get all the bits for a Pi, the price difference is marginal..
Not as cheap but the cheapest Intel Nuc will do the job better than most and also be more versatile. They can run Windows/Linux/Android.
Nah I used to run Futureworld at the Cavendish![]()
Solidrun, they make a unit called cubix.
Spec is far better than the pi and has a case and psu with it. Openelec 5 has full support for it.
I own a Pi and really want the Cubix. Better in every way.
You can pick up the Celeron nuc for £120 and a 2gb stick of DDR3 SODIMM can be found for a fiver. You can run the OS From a USB Key.
NUC is £300, Pi is £35.
I'm interested to know in what way it wipes the floor, as I'm looking for a similar spec myself.
Cheers
Thought about a Raspberry Pi?
Exactly how powerful is a baytrail cpu in the PIPO compared to a Celeron in a NUC?
When playing back a 1080p mkv/mp4 on the Celeron NUC, does it get maxed out?
