- 19 Feb 2007
- Sol
So with Nvidia I usually use Adaptive V-Sync, Does AMD have anything like that ? I can only find either on or off in the CCC
So with Nvidia I usually use Adaptive V-Sync, Does AMD have anything like that ? I can only find either on or off in the CCC![]()
Its coming, probably in the next Driver update
For now you can force it with RadeonPro..
FreeSync
It’s been quite a while since AMD announced its Project FreeSync, and since then a lot has happened. Now, the company is officially launching it, as it is included in the Catalyst Omega driver release. Monitors aren’t available yet, though we expect to start seeing those sometime Q1 2015.
I'm sure it's already enabled in the omega driver.
-EDIT-
Source: http://www.tomshardware.co.uk/amd-catalyst-omega-radeon-driver,news-49364.html
-EDIT-
The only options it has are on, Off and off/on unless the app specifies.
I mean adaptive like Nvidias drivers has built in, It's different to Freesync/G-Sync.
