BSOD, No dump file
4 Feb 2010
Hi there,
Firstly im unsure weather this is the correct place for this thread, so move if needed :)
Starting two days ago, my computer has started randomly blue screening, and im completely unaware to the reasoning, but when this does happen it doesn't dump any sort of file.
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - using Be Quiet! Shadow Rock Pro SR1 CPU Cooler
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive
Asus M4A785TD-V Evo AMD 785G (Socket AM3) DDR3 Motherboard
2GB MSI R9 270X GAMING GFX
OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply
Sony Optiarc AD-7240S 24x DVD±RW SATA ReWriter (Black) - OEM
Fractal Design Define R4 PC Case - Black/Pearl
OP
4 Feb 2010
No not really, i has happened a lot so when it does it again im going to take a photo, and no, no oc at all in the full build
5 Nov 2014
when it happens what are you doing on the PC?
can always try going in to command prompt and typing
sfc /scannow
will check windows files etc and maybe run memtest and run some ram tests
OP
4 Feb 2010
Im not doing anything heavy, just browsing listening to music.
I have ran HD Tune Pro, and got no errors, also ran windows memory test which also got no errors.
Dumps are enabled, but there are old dump files from earlier in the year
OP
4 Feb 2010
KERNAL_DATA_INPAGE_ERROR
Technical Information
*** STOP: 0x0000007A (0xFFFFF6Fc4000A948, 0xFFFFFFFFC000000E, 0x000000008E19C860, 05167f81b
*** ntfs.sys - Address FFFFF8800152904c base at FFFFF8800143D000, Datestamp 5167f81b.
Collecting data for crash dump...
initializing disk for crash dump...
OP
4 Feb 2010
Im not 100% sure about motherboard bios, and what do you mean 850 compatibility?
ATM im in the middle of moving all my **** to External HDD, so i can do a fresh install of windows
Caporegime
11 Jul 2009
BenefitStreetBirmingham
sorry man,i must have read another post saying he added a Samsung 850 evo,you have a crucial m4 though
only just read your first post,i would download ssdlife and check for the firmware version and the hours usage on the m4,theres a 5400 hour use freeze bug on those drives which is cured by updating the ssd fw to a newer version
I don think you need to re install windows,pretty sure its the hours usage bug but check first
