- 19 Feb 2007
- Sol
How did you disable Crossfire?
The little check box under Crossfire-X, I'm guessing that actually just activates profiles and doesn't really disable Crossfire-X ?
Correct. You need to create a profile for Alien Isolation using the game exe A (AI.EXE) and select disable Crossfire at the bottom. No promises this will work as you have a dual gpu card, but it might.
FXAA should get rid of those, you'd have thought.
I know, used to run my 6970's that way, and disable CrossFire via CCC taskbar and run the TV through the second gpu as they ran much higher clocks on twin displays but my 7950's or 70/50 CrossFireX would never output via bottom gpu, they would only output via the top card and never tried the 290's, now I just 'win'+'p' to swap displays.![]()
1.7 patch landed yesterday and AFR is still working as it was on 1.6 if that's any help.
Waiting patiently.![]()
That's what I was talking about, for me it happens after taking a stare at the map, you can get rid of it by changing res, but it comes back, exact same thing when I played Ryse too.
I've tried to no avail![]()
CF worked for me top or bottom on my 3870s, 5970s, 7950s, and 290s. AMD system.
Tommy, think I might have sussed Far Cry 4 and AFR mode. Do not use SMAA. I'm using MSAAx2 with AFR, farmes are super good, solid 60fps and great crossfire usage but more importantly, the horrible shadow that you get in the frame has now disappeared. Must be something to do with SMAA and AFR.
MSAAx2 with AFR working very well, running 1440p vsr, well spotted tony.![]()
