Hey guys,
My last two builds have used uATX mobos as I really didn't need a full ATX board. My current case is a few years old - it's a Coolermaster ATC 201, and several bits have fallen off/stopped working/been removed by force
In short, it's knackered. Even the on/off button stopped working
The other (big) problem with it is that it isn't deep enough to hold my CPU cooler (Gelid Tranquilo) so the side doesn't even fit on properly.
Now I'd like, if possible, to have a smaller gaming PC. I don't use any of the 5.25 bays (no DVD drive); I only have a couple HD drives, and only ever 1 GPU inside.
I'm looking for something that is smaller than a mid-tower, has decent airflow, will accommodate a full size cooler, and a mid-range GPU. No need for water cooling or anything like that.
I'm also a big fan of quiet PCs, so that airflow must not be at the cost of a lot of noise if possible.
As for shape, I'm not bothered too much. A smaller mid-tower, or maybe a cube, so long as it's not a total pig to work on inside.
I just want it to take up less space and look less "1990s workstation"
Budget is about what I spent on the last one - £100 ish.
What are your recommendations?y7uh6 (extra letters there courtesy of my cat
Budget is about what I spent on the last one - £100 ish.What are your recommendations?y7uh6 (extra letters there courtesy of my cat
