I'll grab one at launch no doubt. Getting closer to a single GPU that can cope with 1440P![]()
I still think 21st Feb for Titan X.
I may get either two Titans or Ti's....
or maybe just a third 970.
But the additional memory will be appreciated at 4K - even "just" 6GB.
Or I could keep settings down and wait til next year.....
I called it being 28nm, before anyone else pipes up.![]()
384bit bus so last year, what a disappointment.![]()
Just a guess:
20%+ over GTX 980. Nice gains at higher res.
GTX 980 Ti (6GB) Q3/Q4 2015
GTX Titan X (12GB) Feb 2015
Quit being stoopid'.
You are happy to stay on 28nm and a 384bit bus ?
The technology takes a back seat to the performance.
again the the bus thing, maxwell has load of on chip cache so it not needing to use the memory sub system nearly as much + compression tech means it dont need such a bug bus. The saved die space can be used for other things.
The 8800 GTX "only" had a 384bit bus, while the 2900pro had a 512bit bus and look what was the better card there.
Big memory bus = Bigger die size
