The die on it looks enormous, bigger than GK110.
Indeed there's a die shot compartment towards the bottom of that page. Defo bigger than GK110.
i'm guessing 600mm^2
the 980's with "only" a 256bit bus was still very strong (and better in a lot of case @4k next to 290x's. Even in AMD led titles like Alien: Isolation or GIRD/Drit etc
GM200 + Witcher 3, very tempting..
Yeah it's a monster !!
Gonna have to grab one of these beauty's..
Unless..
AMD can beat it
The one big weakness the existing Titans have v the 290X at very high resolution is the 384bit bus.
As the resolution/settings increase the 290Xs gain more.
) that the GTX970/980 have too so it'll likely perform roughly like a 512bit card anyway.Nvidia Maxwell GM200-400-A1 Die Shot Analysis – Approximate Die Size Calculated
Read more: http://wccftech.com/nvidia-maxwell-gm200-die-shot-analysis/#ixzz3P0b14Caw
You'll probably find that's more to do with 48 ROPS ( Titan ) vs 64 ROPS ( 290X ) and not so much on the memory front.
If they went with a 512bit bus the die would physical have to be 25% larger as the memory controllers are located on the dies outside edge.
Think what increasing the die to that size would do to the yields and price.
You also have to remember that it'll have the delta compression ( Not memory compression) that the GTX970/980 have too so it'll likely perform roughly like a 512bit card anyway.
Looks pretty big. Also, 12GB? We sure that's not just the Quadro version only?
** No hotlinking **Imho we'll see Titan X in Feb and then 980 Ti in Q3/Q4.. Just like a repeat of the 6XX / Original Titan launch.
